Author Topic: Does anyone know what this is?  (Read 5928 times)
Re: Does anyone know what this is?
« Reply #15 on: March 01, 2025, 08:20:14 PM »
Thanks Roger,
That means for Pete (AS) ::) that we hope his engine was built from tried and proven plans rather than someone's pipe dream.
We are still seeking out the original design (I pointed Pete in the direction of Adrian Duncan who might come up with more clues for his specific engine ) but please speak up of you know of any four stroke diesel designs: any of them they might help  :)
Offline dieselpilot
« Reply #16 on: March 02, 2025, 02:03:56 PM »
This will run just fine. Maybe not much compression adjustment, but after the correct load is found it won't matter.
Design a rocker to compress valve spring to whatever your comfortable with. Don't worry about lube, a drop of oil prior to each session will be fine, assuming parts aren't soft, just like the production open rocker engines. If it was designed by the builder, odds are there is no information to be found, and any parts are just as good as the designer's.
