Author Topic: V3 90 deg 'Jota' Engine big bore  (Read 3372 times)
Offline AlexS
« on: December 22, 2019, 09:32:14 PM »
Hello there,
What should you do, when you have ideas and make some sketches the last couple of months?
I will start on make a 3d model of a new engine. And later on build it.
A multi cylinder of higher rpm range. More kind of a 'sport' engine.
I do like three, six and even twelve cylinder engines of there sound an simplicity/engine balance. But something different.
But what about a V3 engine? I only know a couple two stroke bikes that use this engine geometry (Honda NS500).
I was thinking of the next thing.
- 3 cylinder 90 degree bank angle
- 180 degree crankshaft. Where cylinder 1 and 3 are on 180 degree, and cylinder 2 shares the crank journal with cylinder 1. (so it is more a mix of a 180 deg twin and 90 deg V twin engine)
- Big bore B/S ratio around 1.4-1.5
- 3 or 4 valve design per cylinder
- Overhead camshaft while cylinder 1 and 3 shares the intake and exhaust camshafts(cam rollers are shifted 180 degrees)
- Split connecting rods with one piece crankshaft, two smaller bearings on each side, a larger bearing in the middle
- Thinking of 2 split crankcase
- Addition, two primary balance shafts for compensate the piston motion of cylinder 2
- Water-cooled
- Larger cam durations than my one cylinder, higher static compression ratio to 1:8-9
Firing order 1-3-2
1 [180 °] 3 [270 °] 2 [270 °]
Offline AlexS
Re: V3 90 deg 'Jota' Engine big bore
« Reply #1 on: December 23, 2019, 01:18:16 AM »
A rough principle of the bottom block of the V3 engine. Reused some parts and had to modded dimensions.
« Reply #2 on: December 23, 2019, 03:37:29 AM »
Alex,
That sounds complicated, I'm glad you are visualizing how to make this work & not me.
« Reply #3 on: December 23, 2019, 11:49:24 AM »
Hi Alex
The Laverda Jota was a straight 3 cylinder Four Stroke 1000cc with a 180 degree crank for the first six years 1976-1982 and later with a 120 degree crank - is this the one the title refers to ?
Real V3 motorcycles where : 1955 DKW 350, 1968 Suzuki RP68, 1982-1984 Honda NS5000/NSR500, 1983-1984 Honda MVX250F and 1985-1987 Honda NS400R.
A related layout was the W3 engine, although this placed all three cylinders in the same plane, but none of them in the same bank. This was used for the 1905–1915 four-stroke Anzani engine, which was used in motorcycle and aircraft applications.
I have tried to construct something similar to your ideas in Alibre a few years ago, but was never satisfied with the result ....
Best wishes
« Last Edit: December 23, 2019, 01:40:37 PM by Admiral_dk »
Offline tghs
« Reply #4 on: December 23, 2019, 12:35:09 PM »
having road a few bikes, laverda jotas were a bit on the thumpy side at lower rpms, but fast and powerful once up to speed, great open road bike.. when BMW K100's came out (4cylinder inline)fast, even power with a harmonic buzz at certain rpms, I thought the electronic gear indicator was one of those "why?" things.. a few years later when the K75 came out (3 cylinder with a counter rotating counter balanced shaft) it was needed as the motor was as smooth as an electric motor,, best triple ever made
what the @#&% over
Offline AlexS
« Reply #5 on: December 23, 2019, 01:44:00 PM »
Yes indeed Per, this engine is refers to the Laverda Jota straight 3 engine. But then a V3 Jota. Seen that Laverda is not doing business anymore, they could not blame me for use the same name  ;)
The Laverda is known to me. For example, my father rode a 3C Jota from the 80s to around the 00s. I myself can no longer remember that he was still driving it. But funny fact, our current dog and former cat was also called Jota.
But an old neighbour here drove the same bike weekly in the warmer days. And you could tell by the typical sound whether he started it or came back from driving it.
After some looking on Youtube I saw a late 3 radial and early W3 engine. Here the guys are not scared, some fresh burned fuel after breakfast is a good way to start the day.
Offline AlexS
« Reply #6 on: December 23, 2019, 04:23:01 PM »
I was looking for a site that sells CI piston rings. I can remember that I have visited a site that was suggested on this forum before. But can't remember the name :-[
I could remember that they also had rings for a 45 mm bore. And they sold more ready-made attributes for model engine construction.
Thanks!
« Reply #7 on: January 01, 2020, 08:31:36 AM »
That's an interesting design concept and another interesting balance calculation  :ThumbsUp:  :ThumbsUp:
At 45mm bore maybe a moped or garden tools supplier can help with piston rings.
Offline AlexS
« Reply #8 on: January 01, 2020, 03:38:12 PM »
For crank design I was thinking of rotation balance in the mid section web between cylinder 1 and 3. Cylinder 1 and 2 shared the same crank journal and so the extra length and +- 1/2 part of the weight of the connecting rod of the cylinder 2 should be compensate in the mid section web of the crankshaft(like you balance an one cylinder engine). And would be great to add two primary balance shafts in line of cylinder 2, that rotate the speed of the crankshaft to compensate the 'missing' 4th cylinder. So basically it should vibrate like a four-in-line engine. Would be fun to design and build for sure!
Thanks Roger I would look around for a related piston size of used mopeds.
Offline AlexS
« Reply #9 on: November 28, 2021, 01:43:11 AM »
Should I give this project a designing Go? Designing this engine in my head for almost 2 years. Lockdown project.
Extreme big bore, 50 mm 25 mm stroke. 3 Valves operating dohc or even desmo (?) :LittleDevil: Result 150cc
Going for 150cc fuel injection kit (tunable) or right for nitro setup?
Good tuneable carbs? Let me know.
Any ideas are welcome.
« Reply #10 on: November 28, 2021, 07:19:21 AM »
Would you choose 1 carb/injector per cylinder or use a manifold and single carb?
« Reply #11 on: November 28, 2021, 10:58:29 AM »
Well, honestly - there is only one person that can answer that question .... yourself  ;)
But I will certainly be following your progress if you choose to do so - and I'm sure so will others.
Offline AlexS
« Reply #12 on: November 28, 2021, 11:14:32 AM »
Roger,
Both options are possible, but maybe 1 carb or injector would be easier to find a motorcycle type one or to combine throttle linkage. Things that I have to sort out.
Per,
Indeed! I think this would be a nice and challenge project. I saw a video about rotary valve for even V8 or bmw i6 engines, give me fruits to think about.
t=1063s
I'm curious what the transmission looks like of the V8 driving the rotary valves.
Already found 50mm pistons (GY6 big bore (could go bigger to, could be buy and fit or get the ring set and make some delicious ones on the lathe!
Someone known with software like EngMod4T here?
https://vannik.co.za/EngMod4T.htm
« Last Edit: November 28, 2021, 11:24:58 AM by AlexS »
Offline AVTUR
  • West of England
« Reply #13 on: November 28, 2021, 11:53:51 AM »
AlexS
In your first posting you said you were going to do a solid model of the engine first. Have you done so? It could answer quite a few questions particularly if it is too complex. You could try sleeve valves!
Years ago I used to park next to a Jota in the bike sheds at work. The biggest bike there and was ridden by a 5 1/2 foot lady.
AVTUR
Offline AlexS
« Reply #14 on: November 28, 2021, 04:26:13 PM »
Avtur,
I only have the model shown in picture in post nr 9. So the whole engine has to be designed!
Cool idea of the sleeve valves, are these systems also running on high speed engines?
