Author Topic: Easy way of finding centre to drill a hole in round stock  (Read 7956 times)
Offline Jim
  • South Coast of New South Wales, Australia
    • Blue Heeler's Model & Toy Steam Engine Room
« on: May 09, 2019, 05:14:17 AM »
Easy way of finding centre to drill a hole in round stock. I know that a lot of blokes (and gals) know this trick, but I'm sure that there's a lot that don't and it's always good to refresh an idea now and again. I know that true machinists have better and more accurate ways to find centre, but for your average backyard metal basher this is a quick and easy method.
<a href="https://www.youtube.com/watch?v=d9i3MEuhgmI" target="_blank">http://www.youtube.com/watch?v=d9i3MEuhgmI</a>
Kind regards,
Offline Neil-Lickfold
Re: Easy way of finding centre to drill a hole in round stock
« Reply #1 on: May 19, 2019, 12:06:41 AM »
Its the same for setting a tool on centre height .
In the vise, you can use a file and draw file or mark it with marker pen, and rub a piece of metal over the area , as long as it is horizontal.
It will make  at thin line you can pick up on.
I dont use my rule, but use a piece of brass sheet strip.
It only needs to be 70 or so mm long.
It is one of the 1st things that used to be taught to apprence's in the work shop.
Neil
Offline Jim
« Reply #2 on: May 29, 2019, 01:58:02 PM »
Thank you Neil.
Kind regards,
Offline co2
  • Jr. member
« Reply #3 on: July 20, 2023, 12:19:26 AM »
Neat trick but I wondered how accurate it is.
My calcs show that for a 1% (of stock diameter) deviation, the rule angle would be 1.05 degrees, using a 0.05" thick scale.
Pretty good, and 1 degree is easy to see.
Offline Jim
« Reply #4 on: July 20, 2023, 12:54:36 AM »
Its always worked well for me, but the caveat being that what I build/repair doesn't have to meet NASA specifications.
Kind regards,
