Author Topic: Junkers CLM  (Read 113242 times)
Re: Junkers CLM
« Reply #330 on: March 09, 2025, 07:04:09 am »
Thank you both  :ThumbsUp:
A number of little bits now. First the retaining washers for the pull rod bearings then the start of the oil sump. I won't hollow it out yet but need it to close the hole when I test the scavenge system. I finally received the M3 x 20mm grub screws to correctly fix the scavenge piston. They are threaded into the top piston to retain the gudgeon pin with two nuts to hold the scavenge piston on top.
Next up is the drive assembly for the oil pump shaft and injection cam. This has to be removed and replaced over the end of the crankshaft and needs to allow adjustment of the injection timing. It is held together with 2 x M2 capheads.
Re: Junkers CLM
« Reply #331 on: March 09, 2025, 07:08:52 am »
I need a 12mm mandrel with a keyway to keep the gear and the drive sleeve aligned to drill the fixing holes. This was cut using the Proxxon mill. Then the grub screw hole in the drive sleeve which will keep everything (hopefully) in place was drilled and tapped M3.
Re: Junkers CLM
« Reply #332 on: March 10, 2025, 08:15:10 pm »
Next I set up the Proxxon RT to drill the fixing holes. The helical gear is tapped M2. I then moved to the normal RT and mill to cut the timing adjustment slots.
The assembly was then put on the crankshaft to confirm the phasing of the keyway was correct before cutting the cam.
Re: Junkers CLM
« Reply #333 on: March 10, 2025, 10:04:22 pm »
Re: Junkers CLM
« Reply #334 on: March 11, 2025, 07:57:26 pm »
Finally I could mill the injection cam. The profile is the same as I used on the two and four stroke 20cc engine. I don't think I need to be optimising injection profiles yet, just getting a runner is enough.
The flanks and the base circle were milled using the rotary table. The nose was finished by filling, using a radius gauge as a guide. Something was not quite right; I was expecting a 3mm radius according to the drawing but ended up with 5mm  :headscratch: I will case harden it at the same time as I harden the cam follower.
It all fitted together without problems and there was sufficient clearance between the cam and the horizontal helical gear  :)
Re: Junkers CLM
« Reply #335 on: March 11, 2025, 07:59:58 pm »
And finally a family shot.
The next piece will be the scavenge pump inlet valve block and then lots of drilling and tapping to put the various cover plate on the crankcase and cylinder block so I can test the scavenge system.
Re: Junkers CLM
« Reply #336 on: March 11, 2025, 08:17:06 pm »
Nice progress Roger - good to see new parts added to the Family shot  :ThumbsUp:
Per     :cheers:               :popcorn:
Re: Junkers CLM
« Reply #337 on: March 17, 2025, 07:50:14 pm »
Thank you Per  :ThumbsUp:
On with the scavenge pump inlet valve block. This will have a 1mm gasket to the scavenge pump cylinder which will hold the outlet valves in place. The top cover will have some plugs/spigots to keep the inlet valves in their housings. The Hylomar sealant will probably be sufficient but I always like to make sure that things stay in place.
Re: Junkers CLM
« Reply #338 on: March 17, 2025, 08:21:56 pm »
Re: Junkers CLM
« Reply #339 on: March 22, 2025, 10:54:49 am »
Hi Roger
You might already have seen it - but Find Hansen has released a Video (actually two) about how he fixes a Chinise Model Diesel Engine.
Here he reveals some of the important things about his Injector designs - though it might help you with this engine  :cheers:
<a href="https://www.youtube.com/watch?v=v95sGqGpNiI" target="_blank">http://www.youtube.com/watch?v=v95sGqGpNiI</a>
Re: Junkers CLM
« Reply #340 on: March 23, 2025, 02:47:37 pm »
I had seen both videos and have started a gap analysis with my previous 20cc four stroke diesel. The thread is here:
https://www.modelenginemaker.com/index.php/topic,12249.msg290110/topicseen.html#new
Re: Junkers CLM
« Reply #341 on: May 25, 2025, 08:21:17 am »
The next stage is to make the various cover plates so I can seal the crankcase and check the scavenge pump works.
The 3mm thick cover plates for the pull rods could be cut using the Proxxon saw. These are over length so they can be machined to length after they are fixed to the two pieces of the cylinder block.
I had previously made the rear cover plate so I finished the drilling and tapping of that before moving on to the front and end plates. At 5mm thick these needed to be milled to size which is a little tricky as they are right on the limit of my milling table.
Re: Junkers CLM
« Reply #342 on: May 25, 2025, 08:22:31 am »
The end plate needs a 45mm diameter hole for the bearing support and to allow access to the injector cam. As usual I removed as much as I could with a hole saw before boring to size. I started the hole saw with the drill bit in the centre and removed it as soon as I had a ring cut so I didn’t drill into the milling table.
Re: Junkers CLM
« Reply #343 on: May 25, 2025, 03:00:44 pm »
 :ThumbsUp:  :ThumbsUp: :ThumbsUp: :popcorn: :popcorn: :popcorn:
Re: Junkers CLM
« Reply #344 on: May 25, 2025, 04:08:07 pm »
Nicely done, Roger!  :ThumbsUp: :popcorn:
But you're covering up all the fun stuff to watch!  :-\  :Lol:
