Author Topic: Big stroke 55 cc one cylinder ICE  (Read 61515 times)
Offline AlexS
« on: January 21, 2018, 12:12:43 PM »
Hello, this is my building log of first and own design combustion engine. For several months I am busy with building of the engine.
My goal is to make the engine block as solid as possible. So that is one of the reasons that it is big stroker. The engine should have the possibilities to be able to easily adjust.
The swept-volume is 55 cc, with a boring of 39 mm and 46 mm stroke. I want it to run at low to mid range. So let's say 750-3000 rpm.
Intake valve diameter 18 mm with a max lift of 4.5 mm, exhaust valve diameter 14 mm and a max lift of 3.5 mm.
One camshaft fitted two cams that are adjustable. The duration of the cams would be around 200 degrees, I have to go into this further.
I want to make most of the parts by myself. But given that this is my first engine, I also use existing components. Such as piston, valve springs and a spark plug.
Feel free to give comments!
Offline AlexS
Re: Big stroke 55 cc one cylinder ICE
« Reply #1 on: January 21, 2018, 12:29:54 PM »
First I had to turn a new flange to mount a four claw chuck for my lathe. With my current three-claw I can not turn large diameters of rod material.
Offline AlexS
« Reply #2 on: January 21, 2018, 12:37:20 PM »
Start building with some raw material. First part, crankshaft crank cheeks.
Offline AlexS
« Reply #3 on: January 21, 2018, 12:43:15 PM »
Cylinder head. I try to upload photos chronologically as possible, but as wel all of one part.
Offline AlexS
« Reply #4 on: January 21, 2018, 12:49:11 PM »
The diameter for the valve seat of the inlet has unfortunately been larger to 20 mm. Due to a measurement error (x-as movement). :-X
Offline AlexS
« Reply #5 on: January 21, 2018, 12:53:07 PM »
Cylinder
Offline AlexS
« Reply #6 on: January 21, 2018, 12:56:23 PM »
Drill holes for mounting on cylinder head and crankcase.
Offline Ramon Wilson
  • Suffolk in the UK
« Reply #7 on: January 21, 2018, 01:37:40 PM »
By my engine building standards Alex that's one big engine - ten times bigger in fact  :o
That's some nice machining you are doing there - I'll look forward to seeing it progress in coming days
Regards - Tug
Offline AlexS
« Reply #8 on: January 21, 2018, 01:43:56 PM »
Thank you Tug, yeah the reason I want to make a bigger one is the diameter of a standard piston. And the ability to use some larger parts for valve stems etc (round 5 mm). The photos that now are uploaded are from a month of two ago. Recently I had solder the exhaust valve.
I want to upload more, but for some reason it didn't work. Maybe I had to wait some time ;)
Offline scc
  • Lancashire, UK
« Reply #9 on: January 21, 2018, 01:47:08 PM »
Looks an interesting engine. I'm following along too :popcorn:   Keep posting.    Regards       Terry
« Reply #10 on: January 21, 2018, 06:57:24 PM »
Also following your progress Alex.  Nice documentation of the parts so far.
Offline Plani
« Reply #11 on: January 21, 2018, 08:07:06 PM »
Interesting Build! Keep the pictures comig  ;) :popcorn:
Plani
Offline AlexS
« Reply #12 on: January 21, 2018, 10:03:57 PM »
Connecting rod and small-end assembly. I had the idea to fit a 15 mm outside diameter for the small-end bearing. But unfortunately there are no 15 mm drill or cutter. :noidea:
Because of that, I have made a part of material C45 to fit the bearing.
Offline AlexS
« Reply #13 on: January 21, 2018, 10:12:55 PM »
First (rough) work on the carter. Plates  are 6 mm. The squired profiles are 20x20. On the left and right side there would be a plate of polycarbonate, to look inside the engine (if you can see something with running the engine full of oil ;).
« Reply #14 on: January 26, 2018, 08:00:56 PM »
An interesting build  :ThumbsUp: Larger than I can do with my machines. There is a lot of experimentation possible with camshafts, valves etc.  :wine1:
