Author Topic: AOG's steam powered iPhone charger MK 1 completed  (Read 7186 times)
Offline AOG
« on: October 21, 2017, 09:15:31 PM »
The steam powered iPhone charger is complete. The good news is that it will charge an iPhone. The bad news is that the boiler I picked isn't up to the job. With that engine and load I need to hold a minimum of 47 psi to charge a phone. The boiler is only capable of maintaining about 20 psi under load. I did hook it up to my compressor and it worked like a champ. So I have achieved proof of concept. Pictures and a video below.
Here is a video of it charging a phone while operating on compressed air.
I'm not done with this concept. Now that I have proof of concept I will eventually make a mark 2 version with a bigger boiler.
Till next time
Tony
Sent from my iPad using Tapatalk
Offline Gas_mantle
  • North Yorks - UK.
    • My Youtube channel
Re: AOG's steam powered iPhone charger MK 1 completed
« Reply #1 on: October 21, 2017, 09:22:59 PM »
Nice job Tony  :)
I'm surprised the engine needs 47psi to charge the phone though, that seems a lot for a small engine.
What is the bore and stroke of the engine ?
Offline AOG
« Reply #2 on: October 21, 2017, 09:29:51 PM »
Thanks, the bore is .498 and the stroke is .745 inches
Tony
Offline Perry
« Reply #3 on: October 21, 2017, 09:32:35 PM »
Hello Tony, nice setup! Mentioning 20psi not being sufficient.. Is it due to lack of rpm at dynamo at that pressure? If so, have you tried to change gearing ratio? To drive dynamo directly from flywheel diameter. Just my thoughts as I was able to charge phone with probably less power with my stirling engine.
Nice work anyway :)
Offline AOG
« Reply #4 on: October 21, 2017, 09:42:05 PM »
Basically it's a torque issue. I played around with multiple pulley sizes before I settled on 2 to 1. If the pulley gets much bigger the engine will stall. If it's much smaller I couldn't get the RPMs I needed at the generator. I even remade the piston because I was afraid the original was blowing by. No real change in the numbers.
Tony
Offline Gas_mantle
  • North Yorks - UK.
« Reply #5 on: October 21, 2017, 09:43:56 PM »
Is it possible to bore it out a bit and make a larger piston ?
Offline AOG
« Reply #6 on: October 21, 2017, 09:50:11 PM »
Not really, if I go much bigger I will break unto the piston valve bore.
Tony
« Reply #7 on: October 21, 2017, 10:12:59 PM »
Still a nice set-up Tony. Are you getting enough heat to the boiler?
Offline AOG
« Reply #8 on: October 21, 2017, 10:34:43 PM »
I'm useing a Bix ceramic burner. I'm not sure what else I could use. Solid fuel isn't really an option.
Tony
« Reply #9 on: October 22, 2017, 12:33:11 AM »
I think that using 18th century tech to charge a cell phone is really cool. I'll bet that most folks just won't understand.....
Nice work!!
