Author Topic: FT 5 Kit build.  (Read 10776 times)
Offline Tin Falcon
  • Down Jersey USA
FT 5 Kit build.
« on: March 26, 2017, 03:21:46 PM »
About 10 Months ago Folger tech in Milford NH  introduced the FT% printer kit. it is  a large format machine with a 12x12x15 build area. A realy nice looking kit . at the time I had just built a kit a couple monts before. so was not ready.
Two weeks ago I ordered the kit. It arrived Friday afternoon .
So the build begins
Offline Walsheng
  • Norfolk, MA
    • Walsh Engineering
Re: FT 5 Kit build.
« Reply #1 on: March 26, 2017, 06:41:27 PM »
You're a lot younger than I imagined!
Offline Joco
Re: FT 5 Kit build.
« Reply #2 on: March 26, 2017, 07:23:41 PM »
Is that a heated bed machine?
Sent from my iPad using Tapatalk
James
Wellington - NZ
Offline Tin Falcon
  • Down Jersey USA
Re: FT 5 Kit build.
« Reply #3 on: March 26, 2017, 07:26:12 PM »
That is minion v2.1   aka the older of the two grand sons.
and yet more progress starting to look like a printer.
Yes 12 x12 heated bed. and linear rails for the x and y . vertical e rod and tin lead screws for the z. twin motors for z and y.
Offline Tin Falcon
  • Down Jersey USA
Re: FT 5 Kit build.
« Reply #4 on: March 26, 2017, 09:20:47 PM »
This stuff is easy any 5 year old can do it (with 10 years experience) LOL
Offline Walsheng
  • Norfolk, MA
    • Walsh Engineering
Re: FT 5 Kit build.
« Reply #5 on: March 26, 2017, 09:53:54 PM »
I never thought of printing a grand kid!  We had ours the old fashion way.
Are you going to make an enclosure?
Offline Tin Falcon
  • Down Jersey USA
Re: FT 5 Kit build.
« Reply #6 on: March 26, 2017, 10:20:25 PM »
For now i am going to use it open . later i may make some plexi sides for it . If i use opaque material i will have to add lighting.
right now working on getting it built.
Offline Tin Falcon
  • Down Jersey USA
Re: FT 5 Kit build.
« Reply #7 on: March 30, 2017, 02:19:51 AM »
A bit at a time
Offline Steamer5
  • The "Naki" New Zealand
Re: FT 5 Kit build.
« Reply #8 on: March 30, 2017, 05:09:37 AM »
Hi Tin,
 Following along, interesting build.
Like the idea of printing Minions........competition for Chris's elves! Wonder if you can print the chocolate chip mint cookies or will they want homemade ones :lolb:?
Cheers Kerrin
Offline Tin Falcon
  • Down Jersey USA
Re: FT 5 Kit build.
« Reply #9 on: April 01, 2017, 11:20:41 PM »
I am not ready to build a cookie printer. Food printers are still a bit pricey.
Had a friend over today we got most of the wiring done
the aero parts arrived for the extruder.
Offline wagnmkr
  • Lindsay, Ontario, Canada
Re: FT 5 Kit build.
« Reply #10 on: April 02, 2017, 10:24:09 AM »
Coming along very well Tin.
Tom
Offline Tin Falcon
  • Down Jersey USA
Re: FT 5 Kit build.
« Reply #11 on: April 03, 2017, 12:02:59 AM »
Thanks!!! I feel it is going a bit slow. I do need to realize this is a bigger printer and I am upgrading the print head on this one as i build the other one I built to the manual then spent time upgrading later.
Yesterday had a friend over and we made some progress. We got a lot of the wiring done the PS and board installed the z motors wired the x axis wired . The control box assembled and mounted.
Today i hooked up the extruder/hot end . Note this is an E3D Aero setup with an upgraded 40 watt heater and a .8mm nozzle. This is about a $ 130 add on not part of the original kit.  So anyone buying this kit do not expect this extruder/ hot end in the parts bag.
Still building to do need to add the Y,Z limits install and wire the head bed and extruder .
Install and tweak the firmware. terminate the y axis motor wires ........
Offline Tin Falcon
  • Down Jersey USA
Re: FT 5 Kit build.
« Reply #12 on: April 03, 2017, 02:32:26 AM »
And the control box view from the back.
Offline wagnmkr
Re: FT 5 Kit build.
« Reply #13 on: April 03, 2017, 12:17:30 PM »
I really like the looks of the Areo. I think I will order an upgrade kit for the E3D.
Tom
Offline Tin Falcon
  • Down Jersey USA
Re: FT 5 Kit build.
« Reply #14 on: April 04, 2017, 01:25:04 AM »
Wiki here:     https://wiki.e3d-online.com/wiki/Titan_Aero
The aero and titan are designed for a mount to be sandwiched between the motor and the titan box.   if you mount the motor from behind you need to ad a 2mm spacer to make the gears align .
In the instructions but easy to miss.
The upgrade kit only includes the Aero heat sink fan and a bearing you need a titan extruder as well if you do not have a titan it may pay to get  the full kit.  IIRC a titan alone is like $ 67 and a e3dv6  $ 75 and the upgrade $47 or $180 the full aero  kit is 110 .
