Author Topic: 2" Minnie Traction Engine  (Read 42695 times)
Re: 2" Minnie Traction Engine
« Reply #45 on: October 26, 2023, 07:45:25 AM »
On model Locomotives they tend to use the relatively cheap Cast Iron cylinders and liners because of the amount of use the engines get doing public running, accepting that the slight rusting between uses will be quickly rubbed off in use. Most small model traction engines are not going to be steaming/ running 8 hours a month pulling heavy loads.
Gunmetal or bronze is preferred for less used models, it is much more expensive but does not have the same level of TLC required long term.
Online Jasonb
« Reply #46 on: October 26, 2023, 02:04:48 PM »
I just had a look at Blackgate sand the 2" Minnie is a CI cylinder so I would go with a CI liner loctited in. this is the same arrangement a smy 2" Fowler has.
Most locos don't tend to use liners unless someone is cutting from solid as they do not need the annulus around the liner so that steam can travel up from the boiler to the regulator ontop of the cylinder. Most small traction engines of 1" and 1.5" tend to have GM castings, most above that are iron.
« Reply #47 on: October 26, 2023, 02:20:25 PM »
Both of my Loco's cylinders have liners. The use of Liners are good practise on passenger hauling Locos because they are easily replaced  ::)
Offline packmule
« Reply #48 on: October 26, 2023, 02:54:18 PM »
Thanks everyone for your replies.
Yes Jason its a blackgates block so ci it is then. :praise2:
Offline packmule
« Reply #49 on: October 30, 2024, 11:28:28 PM »
Its certainly been a while but work is still progressing.
OK. The casting turned out to be a complete disaster, bull at a gate time.
I first machined the top flat straight out of the box without  actually checking the casting  :hammerbash: When I checked the thickness of the saddle it was already below what I needed as a finished size.
Consigned to the bin.
Not even comtemplating another casting I bought some thick walled steel tube and set about machining, boring out the centre to req'd size then the outside for the thickness. That done I bought a 100 x 100 steel block for the cylinder ,this was  cut on the mill to fit the saddle. As the block was undersize on the width I milled it flat and silver soldered extra steel to give me the width I needed. This was then set up in the mill and both ends milled so I could place on one end and bore out for the cylinder.  Following this I turned a wooden plug to fit in the cylinder so I could place in the vice and roll the block taking light cuts to shape to the radius req'd. The cylinder proper was machined from cast iron to a shrink fit and placed in the freezer over night, then heating the steel block the cylinder was quickly fitted
The ports were milled into the port face as usual practice and the cylinder was then placed in a tilting vice to drill the ways from the cylinder ends. This was setup using a simple jig with 2 equal length adjustable arms  so the end of one touched the inside of the cylinder edge and the other inside the top of the milled port. Perfect on 3 ,on the last managed to move slightly and just caught the edge of the milled port but I think should be ok.
will post some images tomorrow
Offline packmule
« Reply #50 on: October 31, 2024, 04:48:03 PM »
Files from yesterdays post
3came as video instead of photo :???:
« Last Edit: October 31, 2024, 05:01:03 PM by packmule »
Offline packmule
« Reply #51 on: March 05, 2025, 12:45:16 PM »
Hi Guys,
 in need of assistance/ recommendations.
I've finished the cylinder and I'm looking to bolt to down to the barrel but i'm not too sure how many or what size to drill for allowing the steam in.
The book only says a cluster of small holes. I was thinking maybe 7 x 3mm . Would this be too many or not enough ?
Thoughts greatly appreciated,
« Reply #52 on: March 05, 2025, 04:16:01 PM »
I must admit that I haven't got a clue  :-[
But I'm a bit surprised that no one has responded .... then again I don't know how many Mini Traction Engine builders are still left here  :thinking:
Just to be clear - are you talking about fixing the Cylinder to the rest of the Engine or Steam passage in the Cylinder ?
Per        :cheers:
Online Jasonb
« Reply #53 on: March 05, 2025, 04:41:06 PM »
I can't remember what I drilled my 1" minnie but for my similar size 2" Fowler the build notes say "five or six 3/16" holes"  so your 3mm sound a bit small.
If the Allchin were scaled upto 2" the the single hole would be 0.667"
« Last Edit: March 05, 2025, 04:45:22 PM by Jasonb »
Offline packmule
« Reply #54 on: March 06, 2025, 11:51:46 AM »
Hi Per/ Jason,
 thanks for your thoughts. I will increase the size slightly and see what happens .
Per, its the holes from the barrel to allow steam into the cylinder.
Offline packmule
« Reply #55 on: August 31, 2025, 04:19:56 PM »
Hi guys,
in need of thoughts with the port on the cylinder. While drilling tthe last hole from the bore to the port the angle of the vice moved as you can see from the photo.
Would you alter the valve slide or tap and plug the hole and redrill ?
On the plus side while cylinder was on the barrel it passed 2nd hydraulic test so very happy with that.
Online Jasonb
« Reply #56 on: August 31, 2025, 04:29:17 PM »
I think I would be inclined to mill a pocket 2-3mm deep that is a bit wider than the valve and a longer than it's extents of travel and then JBWeld & CSK screw in a thin Cast Iron plate that has had the ports cut into it into the pocket.
Offline packmule
« Reply #57 on: September 03, 2025, 01:08:00 PM »
Hi Jason ,
Thanks for your reply, That is something I wouldn't have thought of.
However it wouldn't help in this case as it was the drill the broke though the port face not a slip with the mill, so although it would tidy up the face it would also block the hole and if I drilled it would follow the same path and I'm back to square one.
So I did tap and thread a new piece of steel in and silver solder either end. Once it was cold I flatted off  both faces repositioned in tilting vice (securely locked this time ) and re-drilled then just cleaned out the ports.
Your suggestion is locked away if ever the need arises. Nice one
