Author Topic: 2" Minnie Traction Engine  (Read 41014 times)
Re: 2" Minnie Traction Engine
« Reply #15 on: March 30, 2020, 11:10:10 PM »
Wow - amazing you were able to reshape that part that well. Very well done!
And I thought I heard some new words floating by the window...
« Reply #16 on: March 31, 2020, 12:36:48 AM »
Yeah, I've had that happen all too frequently!  Not always copper either, so I don't have the 'sticky copper' excuse.  The 'clumsy oaf' excuse is about all I can convincingly muster!
But your salvage job looks good to me!  I'd be pleased with that  :ThumbsUp:
Offline packmule
« Reply #17 on: April 01, 2020, 05:34:13 PM »
Hi guys,
Thanks for your kind comments. I'm sure you may well have heard my comments as they came thick and fast.
I've now started to cut the discs to weld into the front rims to form the tee's  will post more as progress continues.
Offline packmule
« Reply #18 on: November 08, 2020, 04:15:34 PM »
Can't believe its Been so long since I last posted  :o apologies everyone.
 Well work is still continuing although I haven't taken many photos as it was pretty staightforward stuff. Anyway as you will see the front wheels are finished along with some of the gears and the crankshaft. The wheels were a copy of Mal Webbers in the they are welded rings inside the ring and ground back. The crankshaft was done almost to the book except I machined the webs together before  pinning and soldering.
Hope to make more progress now I've retired  :) :)
« Reply #19 on: November 08, 2020, 04:26:11 PM »
Nice to see an update on your project!  Looking forward to more :)
Your last picture looks a bit like a steampunk Tie Fighter!  :Jester:
Offline mal webber
  • Wales UK
« Reply #20 on: November 10, 2020, 08:40:40 AM »
Hi Bob
Still watching this build and it's looking good Bob,  my minne build has come to a stop for now until I finish Howitzer project I have started but when I do start back on the minne will be asking a few questions on the boiler side of things .
Mal
Offline packmule
« Reply #21 on: December 08, 2020, 08:07:10 PM »
 Hi mal ,
Glad to see your still building. I've taken a short break from gear cutting to give my ears and arm a rest.
Started a small build if a stirling engine from Anthony Mount's book. Its a bit fiddley as quite a few parts are only 0.5 thick but getting there
Offline packmule
« Reply #22 on: August 04, 2022, 09:43:46 AM »
At last.........
After a lot of gas and silver solder i've finally managed to seal the boiler and its passed its first test at 200psi.
Now finishing the mounting blocks for the crank, gear and rear axle. These have been cut from steel bar and I'm press fitting bronze bushes rather than steel running on steel. Once these are finished I will fit to the hornplates and it will be onto the rear wheels which I was going to fabricate but in view of the time already passed opted for a pair of Ali castings.
will post pics later.
« Reply #23 on: August 04, 2022, 11:57:41 AM »
Concratulations for Passing the Major Milestone a Pressure Test - that Must have fellt Good  :whoohoo:    :cheers:
Offline cwelkie
« Reply #24 on: August 04, 2022, 01:31:21 PM »
Congratulations on the boiler milestone!
Glad to hear that you are still fitting the Minnie into your life.
Charlie
Offline packmule
« Reply #25 on: August 04, 2022, 03:39:55 PM »
Thanks for comments,
after spending what seemed a lifetime of soldering and chasing leaks if felt fantastic watching the pressure needle rise and not getting wet. There was a small amount of movement in the firebox crown nothing to bother about. The amount of solder that I've used i think it needs hallmarking as well although a fair bit of that is down to inexperience, but I don't  care now as the first hurdle has been passed.
« Reply #26 on: August 04, 2022, 04:07:33 PM »
Been there - the first boiler I did took forever, redoing seams multiple times, finally got it. Several boilers in actually had one pass test first try. I stood there and couldn't believe it!
« Reply #27 on: August 04, 2022, 06:59:30 PM »
Great to hear the progress on the Minnie!  :ThumbsUp:
Looking forward to seeing the pictures too.
Offline packmule
« Reply #28 on: August 08, 2022, 09:13:24 PM »
Pictures as promised of some of the other parts made whilst batting with the boiler.
First up is the boiler showing bronze stays which I threaded and screwed in 3mm stainless rod for the hornplates.
Second is hornplate fitted showing  shaft bearings, (third and rear axle waiting for bronze to make bushes )
Third  is winding drum and brake drum. Had big fun turning these as the steel was EN8 and would only cut using insert tips and light cuts.
Fourth one shows the 80t final drive gear and winding drum ratchet wheel.
Hope I've not bored you to death as no special techniques just plain turning.
« Reply #29 on: August 09, 2022, 12:24:57 AM »
Those are some great-looking parts, Bob!  :popcorn:
