Inspired by builds on this site (I follow most of them quietly, sorry for that) I have started to put together a V8 in Solid works. It will be
based on the Schillings plans (I have bought them many years ago at
www.vth.de), although I do not like the square box looks of that engine. I
will try to get a more detailed and realistic look on this engine, change the water flow through the cylinder block, different valve covers,
electric starter etc. Do not know if this will make the engine “my design”, on the other hand when it is finished it will be a unique one. If
the moderators think it is more appropriate in the “from plans” section please let me know.
My main goals with this project are:
1) Build a working V8 with a combination of manual as well as CNC machines
2) Learn to draw and design with Solid Works
3) Generate G-code of the 3D Solid Works parts with SprutCam V9 CAM software
4) Make the missing tools / accessories for my machines (have a long to do list here) needed to build this engine
I plan to only use the CNC machines where it is required due to part shape or when I have to make multiple items of the same. The crank will
be a build-up style and all the rotating parts will have ball/needle bearings. Initially it will be a glow-plug engine, in this way I
eliminate the distributer and ignition timing. When it is running well on glow plugs I might convert it to sparkplug and even fuel injection.
Since this is my first multiple cylinder engine I prefer to take things step by step....
Below some pictures of the design as it is today, guess I have about 70% – 80% finished.
The very nice thing about 3D CAD software is that you can really tackle design issues in a very early stage. If you look to the section view
below you will see a collision between conrod and cylinder block. Normally I would see this at assembly time, now it becomes clear before the
first piece of material is cut saving lots of time and frustration in a later stage. There is another error visible in this picture, the left
cylinder bore was off by 0.25mm (see the connection between combustion chamber and cylinder bore).
I had a last opportunity to buy material against trade prices (got it over a friend and the department he is working is sold...). I bought
some lengths of 3mtrs of free cutting steel, aluminium, C45 steel and Stainless steel tubing, all in different sizes.
From the scrap yard I collected some aluminium blocks, one piece of 7075 and some pieces unknown but they have milling marks so it should be
ok for machining. The 7075 will be for the cylinder block.
Although the design is not finished yet, I am eager to start making some chips! It will be a very long project and most likely parallel to
others since I cannot focus on a single project for more then 3 to 4 months.... Hope that positing the build here will help me keeping
motivated to bring this project to a proper end....
Suggestions / design idea's etc are more then welcome!
Regards Jeroen
