Author Topic: SB 9 Rebuild  (Read 208392 times)
Goldstar31
Re: SB 9 Rebuild
« Reply #330 on: December 03, 2012, 04:35:53 pm »
It's a bit trickier than that with the older Myfords. If one gets to the stage of avoiding the narrow guide principle, the saddle has to be offset to bear on Number 4 shear instead of the normal number 2 one.
It's interesting. Some Myford owner might ask 'How, when and why'
Sorry, I didn't really want to go off from SB's( whatever they are ) :headscratch:
ooops
N
Offline Dan Rowe
  • Dripping Springs TX USA
Re: SB 9 Rebuild
« Reply #331 on: December 03, 2012, 04:39:52 pm »
SB stands for South Bend Lathe think Boxford as they are very similar.
http://www.lathes.co.uk/boxford/
Dan
ShaylocoDan
Online steamer
Re: SB 9 Rebuild
« Reply #332 on: December 03, 2012, 05:14:31 pm »
Yup.... A Boxford Model A is just about identical to a Southbend 9" Model A.....as well as Hercus, Smart and Brown....ect
Goldstar31
Re: SB 9 Rebuild
« Reply #333 on: December 03, 2012, 05:24:55 pm »
Apologies, gentlemen, English humour :mischief:
It's in the jeans. Sorry, genes!
Online steamer
Re: SB 9 Rebuild
« Reply #334 on: December 08, 2012, 01:05:42 am »
OK...after a stressful, but productive week at work...it's the weekend!
I plan to do some work on the "bend"....but ...I may I may be distracted by shiney things.... :LittleDevil:
Re: SB 9 Rebuild
« Reply #335 on: December 08, 2012, 03:45:12 am »
Understandable. So long as there's PICS of shiney things.  ;D
Re: SB 9 Rebuild
« Reply #336 on: December 08, 2012, 06:30:45 am »
If only stress at work ended up achieving something tangible. Looking forward to seeing your progress.
Shiney things are fun :mischief:.
Online steamer
Re: SB 9 Rebuild
« Reply #337 on: December 16, 2012, 11:15:55 pm »
OK!
The cross slide and saddle are done!
Started tonight by measureing the alignment of the HS spindle with respect to the saddle ways
YUK!
The end of the test bar should be pointing up and towards the front by the. 0005"
Its pointing down. 0015 and to the rear. 002"!
Im going to adjust the spindle bearings first and see where we end upp
Ok.  Considering I only want to do this once.....ill take the spindle apart and put the new belt on
Re: SB 9 Rebuild
« Reply #338 on: December 17, 2012, 12:30:31 am »
We are waiting patiencely Dave, rushing things only causes delays so take it slowly buddy. We want to see it done like its suppose to. You have done wonders so far so keep up the excellent progress.
Online steamer
Re: SB 9 Rebuild
« Reply #339 on: December 17, 2012, 12:56:06 am »
Thanks Don
It should start to pick up the pace now...
The next real challenge will be aligning the leadscrew....
The tailstock should be tediuos.....but straight forward
The tough part is really over
.....at least I think it is anyways
Online steamer
Re: SB 9 Rebuild
« Reply #340 on: December 17, 2012, 02:54:00 am »
Here's a few photo's
Top front of test bar....zero
At end of the spindle...+.0015
In the horizontal plane, at the end of the front of the test bar.....zero
At the end of the spindle....-.002
And to my previous point...as this is a plain bearing spindle.....I need to make sure the bearings are adjusted correctly, before I can do anything about this.   The test bar is 9" long , and the standard is +.0005/12" up and to the front.   This translates to 9/12 x .0005 or about .0003" maximum at the end of the bar.
There doesn't seem to be any affect from tightening the HS clamp screws. That tells me the HS fits the bed pretty well..
Offline swilliams
  • Canberra Australia
Re: SB 9 Rebuild
« Reply #341 on: December 17, 2012, 03:19:40 am »
Hi Dave
So, if necessary, are you going to scrape the bottom of the headstock or the bearings to fix this up?
Online steamer
Re: SB 9 Rebuild
« Reply #342 on: December 17, 2012, 03:26:13 am »
Hi Steve
Yes....The bottom of the casting exactly...but before I do I want to be sure the spindle is fitting it's bearings correctly.  If it really is off that far...it's from one of two things....
The casting distorted with age....or
It was never fitted correctly in the first place.... ::)
It appears to be stable...so it isn't twisted, and it seems to be bearing evenly.
PS...the bearing is split on one side...so scraping the bearing isn't really an option as it would be way out of round and impossible to correct.
Offline Mosey
  • Rosemont, New Jersey, USA
Re: SB 9 Rebuild
« Reply #343 on: December 17, 2012, 01:15:05 pm »
Or, the HS is not original to this machine. Many SB's have been put together from parts of other machines over the years.
Online steamer
Re: SB 9 Rebuild
« Reply #344 on: December 17, 2012, 03:47:15 pm »
I don't know Mosey....the ways would have had to been WAY off for that alignment to make any sense.......
