Author Topic: Dale's k 27 By Kozo  (Read 137831 times)
Re: Dale's k 27 By Kozo
« Reply #240 on: April 27, 2022, 07:10:55 PM »
Offline dalem9
« Reply #241 on: March 24, 2023, 11:50:23 AM »
Here is the work I have got done, Things have been slow for me but I am still trying. I will be away for awhile, I am having another surgery On the 5th of April. I have about 10 more parts to make and a lot of silver soldering and then I will be able to start the tank.
« Reply #242 on: March 24, 2023, 05:01:14 PM »
Looks like a lot of nice parts there!  :ThumbsUp:
Best of luck with the upcoming surgery.
Offline Prowler901
« Reply #243 on: March 24, 2023, 06:54:28 PM »
Awesome work on your little Mudhen, Dale!
Best wishes for a speedy recovery.
Todd
Offline dalem9
« Reply #244 on: April 24, 2024, 11:00:14 PM »
Here are some pictures of the oil pump I am working on. I am finally getting back in my shop. Also I made a hoist so I don't have to lift all this heavy stuff.
« Reply #245 on: April 25, 2024, 12:05:28 AM »
 :ThumbsUp: :ThumbsUp: :ThumbsUp: :popcorn: :popcorn: :popcorn: Good to see you back! :cheers:
« Reply #246 on: April 25, 2024, 05:41:34 AM »
Great to see ou getting some shop time again!
That hoist sure looks like a nice addition.  Wouldn't mind having something like that to move the rotary table, mill vice, and larger lathe chucks around too!
Offline dalem9
« Reply #247 on: October 16, 2024, 11:41:55 AM »
Here is my oil pump for my K27.
« Reply #248 on: October 16, 2024, 12:45:23 PM »
« Reply #249 on: October 16, 2024, 03:56:50 PM »
That pump looks very nice!   :popcorn: :ThumbsUp:
What are the two fittings off to the right? Are they the oil 'receivers' that will connect to the two spigots on the pump?  And does that mean this is a double-barrel pump?  with two outputs instead of just one?
Offline dalem9
« Reply #250 on: October 16, 2024, 04:51:00 PM »
They are the check valves that go on the top of the cylinders. Then a line goes from the pump to the cylinders. Yes it is a two cylinder pump.
« Last Edit: October 16, 2024, 04:55:27 PM by dalem9 »
« Reply #251 on: October 17, 2024, 02:02:01 AM »
Ah... makes sense!  Thanks!
Offline dalem9
« Reply #252 on: February 04, 2025, 11:42:39 PM »
Well I have had some time to work onmy K27.I finished the brakes and am working on the sides of the tender tank, what a pain!Feel good to be working again.
« Reply #253 on: February 05, 2025, 01:01:39 AM »
Wow!  The brakes on the tender are quite intricate, aren't they?!   And you've got a great start on the tank too! :ThumbsUp: :popcorn:
Those pictures really show how large the chassis is compared to the trucks!  Much more overhang than in the A3 Switcher that I made.  You can really see that the K27 is a narrow gauge.
« Reply #254 on: February 05, 2025, 01:21:37 AM »
Great to see you back on  this one!   :popcorn: :popcorn:
