Author Topic: Proper Set Screw Etiquette  (Read 9840 times)
« on: January 05, 2014, 06:27:48 AM »
Or grub screw, if you prefer :)
In my current build, the plans specify two set screws in the fly wheel - 180 degrees opposed.  See the plan excerpt below:
However, I've heard that you should never place set screws directly opposite of each other, because then you're suspending the flywheel on the two set screws and not getting all the additional surface area of the shaft making contact with the wheel.
Would you ever want to use two set screws?  And would you use them opposing as showed? or at some other angle?
Is there ever a reason to have more than one?
Thanks!
« Last Edit: July 24, 2017, 12:56:51 AM by Kim »
Offline stevehuckss396
  • Sterling Heights, MI USA
Re: Proper Set Screw Etiquette
« Reply #1 on: January 05, 2014, 06:33:30 AM »
On the hub on the front of my crankshaft I put 2 screws in. The hub is what the starter spins so it takes some abuse. I put 2 screws at 90 degrees apart that mate with 2 flat surfaces on the crankshaft. Haven't had any trouble sence.
Offline tel
  • Bathurst District, NSW, Oz.
« Reply #2 on: January 05, 2014, 06:35:46 AM »
You have heard right Kim - always use 'em at 90° or thereabouts - never at 180°.
In most cases a single grub screw is enough, but just occasionally you might have install a second one. There is a good case for that with valve eccentrics where, once set properly you can remove one, dimple the shaft, reinstall and ditto repeato for the second one.
Offline awemawson
« Reply #3 on: January 05, 2014, 09:25:41 AM »
Highly stressed parts will often have two grub screws down the same hole, the second one in locking the first like lock nuts. Often confuses people on dismantling . . . 'why can't I pull it off, I've removed the grub screw '  ...  :thinking:
Andrew
Andrew Mawson, East Sussex, United Kingdom.
Offline tel
« Reply #4 on: January 05, 2014, 10:20:23 AM »
  :D Yes, I've been caught by that more than once!
Offline Ian S C
« Reply #5 on: January 05, 2014, 12:13:06 PM »
On the agricultural machinery that I'v been involved with, we make our own chain sprockets etc., they are on 35 mm shafts, with 10 mm keys, our method is; one grub screw on top of the key, the other 90* from that, we use 3/8 UNC x 3/8", seems to hold OK, the shafts sometimes get bent, or broken, don't think we'v ever had problems with the keyed fittings.
Fitted a pulley on a 3hp Kawasaki motor yesterday, noticed that it had one 5/16"grub screw opposite the key, everything is nice and tight, so it's staying that way.   Ian S C
Offline Graham Meek
« Reply #6 on: January 05, 2014, 12:47:51 PM »
Most small engine designs like this are shown with the grubscrews opposing, it is probably done in the belief that it will balance things out. As has been stated earlier the grubscrews are more effective at 90 degrees, and if the shaft has two flats at 90 degrees also this is a very effective means of locking the parts together.
If the two grubscrews were equally displaced 45 degrees either side of top dead centre then the flywheel will add to balance the engine, especially if the there is a disc crank.
My best regards
Gray,
« Reply #7 on: January 05, 2014, 01:57:56 PM »
Andrew
I did the same thing on the V8. Took both 3/8 long screws out and put 4, 3/6 long screws in. 2 down each hole.
I had a problem with the hub coming loose in the middle of the day at Maker Faire Detroit and I wanted to make sure that never happened again. Might be over kill.
« Reply #8 on: January 05, 2014, 02:26:17 PM »
Two screws placed at 90 with jam screws behind them is best practice, however,,,,I hate set screws.
Better off with a tapered collet, or a clamp hub or a taper pin.
« Reply #9 on: January 05, 2014, 10:40:43 PM »
Thanks to everyone who responded with the great information and advise!
I will either use just one set screw, or go with two at 90 degrees as advised.
It never ceases to amaze me how much knowledge is represented on this forum.  And how ready and willing people are to share it!  :)
Thanks everyone!
Offline mcostello
  • Lancaster, Ohio
« Reply #10 on: January 09, 2014, 04:28:02 PM »
If You think 2 setscrews in one hole are a pain, just wait until someone brings in a rush job pulley to be rebored and leaves one in the hole. :o
« Reply #11 on: January 09, 2014, 07:44:27 PM »
Did I mention I hate set screws?
 8)
If you ever get a chance to use these....go for it.
http://www.fennerdrives.com/trantorque/
« Reply #12 on: January 09, 2014, 08:55:26 PM »
Whilst on the subject of the little buggers, I've had several of the smaller sizes round out. A couple were on my last build and some were in , shall we say, Asian built tooling. I've replaced the ones in the tooling with some from the auto parts store and made some square head bolts for my build. Are a lot of the "supplied stuff" just that cheap and soft?
Whiskey
Offline Hugh Currin
  • Box Elder, SD, USA
    • www.currin.us
« Reply #13 on: January 10, 2014, 12:12:29 AM »
 8)
I agree completely, I also hate set screws. This particularly for withstanding torque. I have used set screws bearing on top of a key. This works well to keep the "thing" from moving sideways but the key takes the torque. Most commercial sprockets I've seen come with two set screws at 90deg, one on top of the keyway. I've typically left the second set screw out, only the one over the key. Thus, if the set screw leaves a ding, it does so on the replaceable key not in the shaft. If one dings the shaft it makes removal harder. Can also file or machine a flat on the shaft for a set screw, then the ding is below the shaft diameter. But I'm with Dave, I hate set screws.Set screws work even less well on hardened shafts.
Tapered bushings (QD type) work very well, with or without a key. I haven't seen any small sizes though. I've also used the Fenner Transtorque that Dave mentioned. They work very well and only require a straight shaft and a straight bore. They're available at least down to 1/4" bore, but they are expensive. The 1/4" bore from MSC (USA) is $50. On larger stuff I've used a split collar with a bolt pattern machined into it. The bolt pattern holds the split collar to the hub to be restrained. Not as good as a key, but OK.
I've been considering what to use for model engines. I'd love to use Transtorques but can't justify the cost for a hobby. Maybe try to machine up a taper lock hub. Oh, I also hate pins holding a hub to a shaft, particularly if it's not meant to be permanent.
That's my story and I'm sticking to it. Thanks.
Hugh
Hugh
« Reply #14 on: January 10, 2014, 01:19:24 AM »
I have no problem with set screws. I learned as an apprentice many many years ago to use two set screws at 90 degrees. I find the biggest problem with small set screws as used on model engines, is that either the hex hole in the set screw rounds out, or the hex wrench itself rounds off on the end. (even the expensive ones).
