Author Topic: A Novice Mistake  (Read 9372 times)
Offline Damau
A Novice Mistake
« on: June 07, 2013, 01:42:40 AM »
My current project, b.lindsey's ME-! mill engine uses a screw made from hex steel and threaded 4-40 to fit through the connecting rod and into the crankdisc.
All was well with the machining of the hex and turning down the shaft for threading with my 4-40 die until I reached for the die that I thought I had.  I did not have a 4-40 but I had a 4-36 and my first thought was, Ök, 4-40 vs. 4.36, what a little difference that is so I will use the 4-36 die.
Wait a minute!!!!!!!
I had already tapped the hole in the crankdisc to 4-40 and the 4-36 was not going to "fly".
Off I go to my favorite online supplier and ordered a 4-40 die and it arrived on the little brown truck today.
I still had the part chucked in the lathe and threading was a "breeze"  (simple chore).
I had allowed some extra length on the screw and knew I could bring it to the correct length after the threading was done.  That was the beginning of my big mistake.  I stepped off the length and had my DRO set to zero and proceded to face the end of the screw to the correct length.
I am sure a lot of you folks know what happened when I tried to face the end of a screw that is less than .100 dia.  I made 2 cuts of about .005 each before the work piece climbed up on the tool and bent the the work piece.  UUUGGGHHH
If you people in Europe, New Zealand and Bill at UNCC in Charlotte and the rest of the world had been listening you would have heard something like a sailor has a reputation for doing.
I had machined the screw with a hex and turned it to the proper length, waited on the little brown truck to arrive, cut the threads and was proud of my job until my bubble went "pow".
Guess what????? I straightened that little booger out and it ran concentric'.
Thanks for another blessing!!!!
Dale Mauney, Shelby, NC
WA4BBN (Amateur Radio Callsign)
Re: A Novice Mistake
« Reply #1 on: June 07, 2013, 02:09:45 AM »
Bummer Dale. It should be fine, but where it bent could be weaker now, especially if you undercut where the thread and shoulder meet.
« Reply #2 on: June 07, 2013, 02:31:47 AM »
Dale I know I have done this once, you seem to learn quick after a mishap like that. Bummer isn't it?
Offline Damau
« Reply #3 on: June 07, 2013, 06:00:46 AM »
Bill and Don,
Thanks for your replies.  I think it will be ok since it was not undercut.  I cut the threads up to the shoulder that prevents it from getting tight on the connecting rod.
Don, the old saying, "experience is the best teacher" certainly applies in this case.
« Reply #4 on: June 07, 2013, 07:14:18 AM »
Dale,
Bending the bolt has caused a weak point (stress fracture) so it would be better to make a new one, especially if you are going to use it associated with a crank.
If you want to shorten a thin bolt the easiest way for a beginner to do this is to put a nut on it, hold it in a vice cut it down with a small hacksaw and finish with a file rounding the ends. As the nut is unthreaded it will clear out any burrs on the threads  ;).
Offline Alan Haisley
« Reply #5 on: June 24, 2013, 10:14:19 PM »
I made one of these from a piece of hot rolled steel. Each hole is tapped for one of my commonly sized screws. The slit was made with a jeweler's hand saw but could be made with a slitting saw in the mill.
The original example of this tool had it case hardened after all the cutting but mine isn't hardened at all so eventually it will need to be remade.
In use, you screw the screw in as far as desired, clamp the plate edge on in a vise, and saw and file the screw to length.
I made mine so I wouldn't need to stock a bazillion lengths of each size screw.
Alan
Offline Bezalel
  • - Skype:Bezalel2000
« Reply #6 on: June 25, 2013, 01:06:02 AM »
Hay! Thanks Alan
I like it  :ThumbsUp:
Alas! another briliant little bl*****y gismo I need to make   :cussing:
Queensland - wet one day, humid the next
Offline MuellerNick
  • Germany // Outback of Munich
    • Motor-Manufaktur
« Reply #7 on: June 25, 2013, 08:32:03 AM »
[size=78%]Don, the old saying, "experience is the best teacher" certainly applies in this case.[/size]
Part of that experience is called "planing ahead". It is about what machining steps to do at what time. And what might happen at each step. And having the experience what steps are a piece of cake, what steps are risky and what steps are sure to fail.
In buzzword-language it is called "risk-management". :)
Don't worry, every machinist has to make these mistakes by himself.
Nick
Offline mike 44
« Reply #8 on: August 09, 2013, 11:30:52 PM »
Alan, good idea, I made the separate nuts or coupling nuts if I could find them. Any oddball sizes I made from hex rod .Your idea is better,
mike
« Reply #9 on: August 10, 2013, 10:41:07 PM »
I was able to find the original source of this idea. It came from Bob Shores and was posted on the Florida Association of Model Engineers website. Bob - and others - have several useful ideas posted there; worth checking out.
Alan
