Author Topic: A little FLASH of inspiration!  (Read 2973 times)
Offline divided he ad
« on: April 25, 2013, 12:22:49 PM »
I was prompted be Bogs to display my little rocket torch for those who haven't seen it.
BTW, why not show them that fantastic little torch you showed me when you called, and don't keep such wonderful little things such a secret.
So....  Lady and gentlemen. My Flash Gordon inspired rocket torch (Flashlight ;) )
OK.  Not that exciting! But it's my latest completed project (plagiarised myself again. Sorry if you've seen all this before)   :)
We start with some phosphor bronze.
Drilled and threaded as my torches are..
First error of the build... Shattered parting tip... Bronze is chewy!
Finished the parting off with a hacksaw!
Made the tailcap thread and used it as an arbour.
Set the compound over and started the angled cut...
Got to this stage and...
The end fell off!!   :cussing:
So, the Mk2 was constructed and had less of a taper and much thicker side wall.
The cunningly hidden join of the two halves. Done this way cause once the nose is shaped it would be near impossible to get the two halves to match up.
A special version of the LED was created to deliver the LED to the end of the torch. The rim was machined off so the LED passed through the 5mm bore.
One leg was insulated with heat shrink and then both legs passed through an acrylic tube before they are bent through and around the insulator disk.
An arbour was made from a bit of hex with a male and female thread. This was used for the cross drilling for the keyring hole (something I keep thinking I should not have done?)
It is also used to make the slots for the fins later.
The cone was made free hand step cut and then shaped. Finished with files and emery.
Close to how it was drawn   :)
The slots were cut at 120' using the hex arbour and digital angle gauge.
The fins are made from stainless. This is the second set as I tried to drill the holes in the first set after shaping.
Realising I'd need them for the silver soldering later.
It all went horribly wrong  :facepalm:  (I was so annoyed at myself   :wallbang:   this was the cause of a 6 month delay in this build!)
Anyway,  this is the Mk2 set of fins. Made from 4mm flat bar stainless and thinned to 1.8mm. Stuck together with double sided tape and cross drilled.
I used the drills to keep the bits from moving while I shape them with the mill... I made little dowels for when I filed and finished the edges.
I made a special arbour and mounted the base section to a slow moving geared motor from a kids mirror ball.
This allowed me to silver solder all three fins at the same time. The flux was applied then the fins and then some silver solder foil (I know...Never knew it existed either... Got it from Bogs). Then bound with stainless spring wire (also from Bogs)
This is the end result -
After 3 hrs of cleaning and polishing!!!
Finished! (Well, nearly...)
Decided it needed a launch platform  :)
The final "arty farty" shot (I know, finally! :lol: )
Well, that's it 20+ hours that I can recall. But when you have an image in your head!
(normal torch build time... 2-3 hours depending on styling)
Ralph.
If you are interested in the complete process I use to build a standard torch....
http://www.youtube.com/playlist?list=PL5226C65B103F3DBE
Offline metalmad
Re: A little FLASH of inspiration!
« Reply #1 on: April 25, 2013, 02:59:59 PM »
Top Job
I love it!!
« Reply #2 on: April 25, 2013, 03:02:39 PM »
That is really cool.
Neat gift idea!
Offline Bearcar1
  • Chicagoland Area, USA
« Reply #3 on: April 25, 2013, 03:22:56 PM »
Way cool. It reminds me of my younger days and Buck Rogers  :Love: .... beautiful finish to boot  :ThumbsUp:
BC1
« Reply #4 on: April 25, 2013, 06:18:42 PM »
Thanks guys  :ThumbsUp:
Glad you like it. I was reminded by Dek of an old show/movie called "destination moon" I'd never seen the black and white filmed version but I had seen the Tintin animated version as a kid.
The Buck Rogers ones are also very similar. I went through hundreds of pictures a while back to see what designs were out there. Saw lots that looked too flimsy for what I had in mind.
A similarly fun one. I made after a conversation about fibre optics and disco balls (as you do!)
The massive GID ball torch.... This is really heavy for a keyring!
Ralph.
