The fly wheel, I had picked up a piece of 2" brass rod at the scrapyard (£3) recently. It had the centre bored out at one end, I also had a short piece of 1" rod. Parted off 1/2" and opened out the bore and pressed the 1" rod in, then did the same for a 1/2" rod, this saved a lot of swarf.
This produced three ratio for the take off belts. I intend to make a well with a pump, a hammer worked off a cam and a dynamo with a lamp.
