Author Topic: engine fro grandson  (Read 27056 times)
Offline hammer
engine fro grandson
« on: March 06, 2013, 09:53:09 PM »
I have just finished a small engine & boiler  for number 1 grandson. I have another but he is only 18 months, but wile I am in the mood I will build a second now. Photo 1, the first one complete with its box.Photo 2. Raw materials, I was given the 2" tube just the right length. Also given 2.5" cut some of this for the end cops. Photo 3, The former .75" ply a bolt , nut & 2 washers, held in the vice.
Offline stevehuckss396
  • Sterling Heights, MI USA
Re: engine fro grandson
« Reply #1 on: March 06, 2013, 10:39:42 PM »
Very cool. I hope to make things for my grand children some day. Need grand children first.
Offline AussieJimG
  • Bywong, NSW, Australia
« Reply #2 on: March 06, 2013, 10:59:25 PM »
That is beautiful and something he will value all his life. Things like that are passed down through the generations. Thanks for sharing.
Offline hammer
« Reply #3 on: March 07, 2013, 07:54:56 PM »
This is just a simple build compared to all the great engines  :NotWorthy: :praise2: :NotWorthy: on this site.  My interpretation of a Tubal Cain design, using what I have to hand.  :DrinkPint: No 3/8" tube in stock, so drilled & reamed 3/8 bar, to 8mm for cylinder, turned end cap from same. I already had the port block, the other half of a 3/4"+3/4" block drilled down the centre then cut in half, used on other engine. I did silver solder the block to the  :ThumbsDown: cylinder before drilling & tapping 6BA for the pivot pin, so had to be very careful not to enter the bore doing it after.
Brazed the end caps in the   :zap: boiler tube, used Rothenberger S2, no flux required higher melting point than silver solder & I was given a box full. :whoohoo: Bushes turned & taped, bottom of flue flared, then all silver soldered in. Then into the citric acid for an hour, then wash off then time for dinner. :stir:
« Last Edit: March 07, 2013, 08:03:20 PM by hammer »
Offline hammer
« Reply #4 on: March 08, 2013, 08:19:45 PM »
Only made the piston & con-rod today.  :shrug: I don't know what the piston is made off,  :shrug: some sort of brass very hard, had to sharpen lathe tool twice.  Almost copper coloured as can be seen against the con-rod. In the photo the swarf came of the piston like shavings from wood, but the brass the normal chips. The rod & big end turned in one piece from 1/4" brass hexagon.
« Reply #5 on: March 08, 2013, 09:47:02 PM »
This is just a simple build ...
Not for many of us.  ;D And certainly not when it's a gift.  ;D
Very nice idea.
Offline hammer
« Reply #6 on: March 12, 2013, 09:42:17 PM »
Had a couple hours play today.  :lolb: Made and fitted the fire box ( to grand a name really ), along with two mistakes.    :facepalm2:
First I cut the shape from a one (UK)gallon can, then I drilled the air holes on the wrong edge.  :cussing: I did get over this by riveting a strip of copper across the bottom to save the day. Cut a base from 1/16th M.S. plate soft soldered the two parts together, I find this harder than brazing or silver soldering.
I had fixed the bottom end cap 3/8" up from the end of the boiler tube, so not to have to tap (8 BA) into the joint when fixing the fire box. Tapping the third hole I broke the tap,  :cussing: :cussing: the first one ever on my home made tapping stand. Managed to get it out with a centre punch (not a tiny bit proud ether side). Then the hole was to large, but as it was below the cap joint I was able to dress the copper with a small hammer to close it over, saved again. Gave it a coat of BBQ paint on my home made rotating table which uses a motor from an old microwave.
« Last Edit: March 12, 2013, 09:46:03 PM by hammer »
Offline hammer
Re: engine for grandson
« Reply #7 on: March 15, 2013, 09:31:21 PM »
A little progress, turned the funnel cap from an odd end of 1" brass. Made the standard from 1/16 stainless plate, (acquired off a coffee machine). Cut & drilled the poet block, silver soldered them together. Never silver soldered stainless to brass before, worked OK. Also turned some plugs so I can pressure test the boiler.
« Reply #8 on: March 16, 2013, 08:38:14 PM »
I know somebody's grandson is going to be excited. Great job Hammer you are making it look easy.
« Reply #9 on: March 16, 2013, 08:46:15 PM »
"Poet block"? Never heard that term before.  What does it mean and what's its origin?
Offline hammer
« Reply #10 on: March 16, 2013, 10:34:22 PM »
I would have though some one as clever as you Merv would realise that the E is next to the R on a key board & it should be PORT. Beside the fact I never cood spel.
Raggle
« Reply #11 on: March 16, 2013, 11:02:05 PM »
Marv, poet block is a form of writer's block, notably when you can't find a word to rhyme with "orange"
It's been said nothing rhymes with orange. They're wrong. It doesn't.
Ray
« Reply #12 on: March 16, 2013, 11:31:31 PM »
Sorry, Hummer, I don't have the patience to do combinatorial analysis on what people write.  I'll deal with it another way.
Offline hammer
« Reply #13 on: March 17, 2013, 03:56:44 PM »
Turned the bearings from the same hard brass used for the piston. Completed the crank & shaft, threaded 3BA fixed with loctight. Just need oiling holes in bearings , polish and final alinement when bolted to the firebox.
Also in the picture springs from an assortment of ballpoint pens will find one for the safety valve. The 2 lumps of brass are for the flywheel, the smaller bar will have to be silver soldered into the hole in the other. This was found at the local scrapyard and had the centre removed. The plug is for the level hole, it is important to undercut the seat so the grommet can't push out under pressure. Not that much pressure will be involved here. But a lesson  O:-) learned when testing @ 50psi.
Offline hammer
« Reply #14 on: March 19, 2013, 09:19:10 PM »
Mark 2 safety valve. Managed to reduce the size. First by hollowing out the underside of the adjuster to take the end of the spring.  Also lowering the ball seat down from the body into the thread area. Completed in an hour, by keeping the same thread 5/16"+ 32 for the adjuster as in the boiler bush. First thread to fit bush & centre drill, open out 3/16" for full length of body & part off. Drill & tap same thread in the piece left in the chuck & screw the body in.  Push back into the chuck, drill the seat with a 3/16"D bit , then drill & tap for the adjuster, carefully measuring depth each time. Pull out and remove the body, tighten & part off 1/8" for the locking ring.   I turned the plunger  from 3/16" hexagon this fits the hole but lets steam out.  Finally  thread 5/16" rod drill centre grind 4 slots  around edge then part off & assemble then set 20psi with air line.
 Lagged the boiler, where did the raw materials come from?? Sticks stuck on with 5min epoxy 12 at a time.  With approx 1.5" to go measure, then measure across the laid sticks to check the fit. reduce remaining sticks slightly if needed, no one will notice, thinking I worked it out mathematically.
« Last Edit: March 20, 2013, 03:40:09 PM by hammer »
