Author Topic: How to use a flycutter??  (Read 2530 times)
Online Sanjay F
« on: September 09, 2026, 12:10:37 pm »
On using the face mill for refinishing the cylinder and mouth piece bolting faces, the surface you have there looks fine for purpose, but when you want a better finish for functional or cosmetic reasons, a fly-cutter will generally do that, especially with a radius at the tool tip, and a sweep radius sufficient to cover the whole surface in one pass.
Charles gave me this bit of advice and I really do need to bite the bullet and learn to use a flycutter - I have a set which came with a load of other tooling years ago but have never tried it out! ::)
I found to 'bits' which fit, one 1/4" and the other 8mm" which fit into the medium and large size cutters respectively. I'm looking at the 1/4" Presto one and that looks like its tip is fit for purpose? The larger one looks very pointy and maybe should be radiused as Charles has stated?
How should I do that, with a file, emery, grinding wheel?
Any advice greatfully received as usual!
Also presumably I put it in collet then into the mill, but what rpm should I be running and what's an acceptable depth of cut?
Offline Rledoux313
Re: How to use a flycutter??
« Reply #1 on: September 09, 2026, 01:20:58 pm »
No time like the present!
A fly cutter can be treated similar to the lathe in many ways. The tool grind is similar to a turning tool, but you may need a little more relief on the bottom edge to prevent rubbing depending on DOC. Speed will be set to achieve the correct feet per minute on the tool, only you’re turning the tool instead of the work as you would on a lathe. As for feed you likely want something small, maybe a thou or two. A fly cutter is a finishing tool more than a material removal tool so light cuts are probably best. I use the app “FsWizard” for speeds and feeds pretty often.
One other thing I notice is that you may have the tool backwards in the cutter. The “top” of the tool or the surface doing the cutting should be facing the set screws. This puts the cutting edge on centerline of the cutter.
The best part about a fly cutter is that the tool can be easily reground. So if you burn it up, or want to try a different geometry it’s an easy and low cost experiment. Good luck!
« Reply #2 on: September 09, 2026, 01:26:51 pm »
You will only get a flat surface using a large cutter if the Mill tram is spot on. Many prefer a nice sharp small cutter and traverse the face many times which will give a flatter face.
I'm not averse to an angular corner but if it is shiny you are looking for then a small radius will do but does increase the length of the cut which can bog down a non geared/belted modern mill particularly as the swing diameter increases and rpm drops.
Speed will depend on the diameter the tip is rotating at. for HSS you want about 25m/min so 30mm dia 275rpm, 50dia = 142rpm, 75mm dia = 110rpm. Feed also needs to be slow as you only get one cut per rotation. start with 0.5mm depth of cut.
That's why I like insert face mills, you can run them much faster and feed even faster again. Hardly use my flycutters since getting them.
I saw this pdf drawing in a book some guy wrote about Milling for beginners ;)
« Last Edit: September 09, 2026, 01:30:46 pm by Jasonb »
Offline ShopShoe
  • Central Iowa, Central USA
« Reply #3 on: September 09, 2026, 01:37:24 pm »
I am one of many that believes a fly cutter should be in every cutter collection, even if you use indexable cutters for some of the jobs traditionally done with a fly cutter.
For general information, let your search engine loose and you'll find more information than any one of us can put together quickly. I just tried "making a fly cutter" and found lots of info easily.
From my experience, balancing cutting-edge geometry, feed rates, etc. is pretty much like using other cutters.
I grind my fly cutter tools old-school on a bench grinder, just like lathe toolbits. If you acquire more unground ones you'll have several chances to practice grinding them and cutting with them so you can contrast and compare. I have reground some chipped brazed-carbide toolkits with radii as well as grinding several all-metal cutters. (I have a green wheel for grinding carbide and typical stock wheels for steel.)
In use, I balance tip radius vs. sharp-pointed-ness and amount of cut vs. speed to cut efficiently without chatter and so the chips come out clean and as small curled pieces. I decide on whether or not to use lubricant/coolant based on material being cut and need to keep things cool and not abuse the cutting edges.
What have I done with my fly-cutter?  Mostly I have used it to clean up or dress large surfaces of material that will be further machined with other tools or machines. In smaller sizes, I have used a fly cutter to dress and square up small blocks for tooling I have made. It's great for making custom-diameter cuts for which I don't have a factory-made cutter. Material cut is mostly aluminum or ferrous metal. A couple of extreme examples include dressing a piece of 6-inch channel steel to make a base for a model and making a section of railroad iron flat on top and square before grinding it more flat to make a small bench anvil.
Have fun and let us know what you accomplish.
ShopShoe
P.S.: I like your restoration projects and I envy your ability to find the rough projects to work on.
SS
Online Sanjay F
« Reply #4 on: September 09, 2026, 01:54:32 pm »
Thanks everyone, the tool bits you see are just out of a box of stuff, I'm not sure what they are or what they were for yhey just happened to fit! I have zero experience with grinding tools (bar a profile tool I experiemented with), but the picture Jason has sent gives a good indication of what is required.
If I started with a blank tool what should do? I have a bench grinder so that's a start, but it's the angles etc I'm not sure about?
EDIT: Hi Jason, presumably the diameter metioned is the diameter of the cirlce which the cutter will rotate/traverse?
« Last Edit: September 09, 2026, 02:35:53 pm by Sanjay F »
Offline Charles Lamont
« Reply #5 on: September 09, 2026, 02:37:35 pm »
You would use your bench grinder. It does not matter that it will produce a slightly concave face. You should read up about cutting tool angles. First you need clearance angles away from the tip. These want to be about 8 or 10 degrees, whatever the metal (more for plastic). Next are rake angles. These are the angle(s) that the cutting surface slopes away from the tip. They depend on the material and are a matter of debate. Typical values are 0° for brass and cast iron, 10° for mild steel, and 20° for aluminium. In practice, you can usually use about 10° for most jobs. For tip radius, I would start with something like 1 mm.
It helps a great deal if your bench grinder has work rests that are better than the frequently seen bits of bent tin, and it is particularly useful if they can be tilted away from the wheel to provide the cutting angles.
If you want to be fussy, you would finish the tip radius and edge with a hand held hone. Start with a grey corundum one, half-inch square and preferably 6 inches long (4 would do at a pinch). The concave surface left by the grinder helps with this as the central part can be left as ground.
This diagram may help.
Also a visit to the TEE stand at MMEX for Workshop Practice series books.
« Last Edit: September 09, 2026, 02:48:01 pm by Charles Lamont »
Online Sanjay F
« Reply #6 on: September 09, 2026, 03:20:32 pm »
Firstly I'm glad I trammed the mill - it was out!
I'm being a dumbass, first of all which way up should the tool bit be, like in the first pair or second pair of photos? Secondly can someone sketch the angles onto the tool tip on whichever is the correct photo please; I'm struggling to understand the diagrams and I've even watched a video ............thank you!
« Reply #7 on: September 09, 2026, 03:41:18 pm »
If you have a bench sander/liisher that will also do the "grinding" it's what I used for that one in the photo which is only a cheap Clarke job.
You can always sitck a left hand insert turning tool in the flycutter ;)
Yes diameter is the circle that the cutting edge is rotating at.
Did you open my pdf with teh drawing and stage sof how to grind a flycutter?, it's a bit hidden above the photo.
« Reply #8 on: September 09, 2026, 03:43:18 pm »
Online Sanjay F
« Reply #9 on: September 09, 2026, 03:46:11 pm »
Yes, I did open your diagram and still struggled to orientate the tool bit the correct way round and work out which angle was what!  ::)
« Reply #10 on: September 09, 2026, 04:16:26 pm »
So from my drawing.
Grind 1 would be positioned facing down towards the work, grind 2 would be facing the direction of feed and grind 3 flat or rounded mid way between the two. The arrow shows the direction of view for the three image sthat have the angle marked
« Reply #11 on: September 09, 2026, 04:33:32 pm »
<a href="https://www.youtube.com/watch?v=c74lw-skM7o" target="_blank">http://www.youtube.com/watch?v=c74lw-skM7o</a>
Online Sanjay F
« Reply #12 on: September 09, 2026, 04:49:11 pm »
I didn't see your posts until now, but here are my 1st attempts at tool bit grinding and using the flycutter (speed 210 rpm as the diameter was 40mm ish) and the photo showing the result ............guessing it's not going to win any prizes, but what do you think?
https://www.youtube.com/shorts/opWMsPYaFC4
https://www.youtube.com/shorts/VA5qUQAyw-0
« Reply #13 on: September 09, 2026, 04:55:17 pm »
OK if you want to make models of Badgers
I can't see the first grind No 1 which may be causing the tool to rub
<a href="https://www.youtube.com/watch?v=rUo0cWFt6Tc" target="_blank">http://www.youtube.com/watch?v=rUo0cWFt6Tc</a>
Online Sanjay F
« Reply #14 on: September 09, 2026, 06:02:10 pm »
 :Lol: - yep badgers!
Ah right got it, let me try grinding that face and see what effect that has
EDIT: Where's that left handed insert turning tool which can fit in the flycutter? ;)
« Last Edit: September 09, 2026, 06:10:36 pm by Sanjay F »
