Author Topic: What alloy to use for a crankshaft?  (Read 401 times)
Offline JPar
« on: August 01, 2026, 02:27:48 am »
The crankshaft in my Galloway 5 HP 1/3 scale engine has a few issues.  This is a fabricated crank, and the main problem is that one of the shafts is a loose fit in its web.  It's held in place by a pin, but it should have been silver brazed as well. I've decided to make a new one, rather than try to repair it. The shaft is 0.625" (5/8) in diameter, the stroke is 3.375", and the overall length is 10.5 inches.
What would be the best alloy to use? The drawing just says "CRS". It needs to be silver-solderable, as well as
adequate strength, decent machinability, etc.
All suggestions appreciated.
Thanks,
Re: What alloy to use for a crankshaft?
« Reply #1 on: August 01, 2026, 07:05:01 am »
The CRS applies to the webs, I would use EN3 or EN32B bright flat bar.
For the shafts I have used both silver steel (drill rod) and PGMS - Precision Ground Mild Steel for crank shafts. I think I used the Silver Steel option on my one.
Offline JPar
« Reply #2 on: August 03, 2026, 01:11:39 pm »
Thanks for the reply.  I've ordered some material (1018 and drill rod) and am awaiting its arrival.
