Author Topic: A vertical steam pump.  (Read 1482 times)
Re: A vertical steam pump.
« Reply #45 on: July 07, 2026, 07:47:02 pm »
I’ve finished the connecting rod between the eccentric and the slide valve. I was curious to see if the pump would turn when I pressed the compressed air hose against the inlet. The joint currently uses just a simple M2 screw; that will be changed later. The pump valves are also still missing.
Michae
https://youtube.com/shorts/T8Qknv03bMw?is=euOearGT2D5MOuV5l
The initial test run was performed without seals on the cylinder or stuffing box. The piston does not yet have a piston ring, and the slide valve was only roughly adjusted. Still, I am pleased that the engine turns.
Now, everything is being disassembled, and the iron parts are being painted.
« Last Edit: July 07, 2026, 07:57:22 pm by Michael S. »
« Reply #46 on: July 07, 2026, 08:17:19 pm »
Even without those last parts and the seals, its running very well!!
Offline Sanjay F
« Reply #47 on: July 07, 2026, 08:25:30 pm »
It looks gorgeous and runs great without all the seals etc. You've really made something special there, congratulations  :popcorn: :ThumbsUp: :ThumbsUp:
« Reply #48 on: July 08, 2026, 08:19:38 pm »
That's a beauty Michael and what a smooth runner already!  :NotWorthy:
« Reply #49 on: July 09, 2026, 10:26:49 am »
Looking good  :praise2:  :praise2: I've always liked scotch yoke engines  :)  :ThumbsUp:
« Reply #50 on: July 09, 2026, 11:14:40 am »
Thank you, Chris, Sanjay, Paul and Roger.  :cheers:
« Last Edit: July 12, 2026, 06:44:40 pm by Michael S. »
« Reply #51 on: July 12, 2026, 06:42:14 pm »
Some small progress has been made on the steam pump. The parts to be painted are currently with the painter.
While the parts are drying, I’ve fabricated a simple main valve and a T-fitting with a displacement lubricator. All that’s missing now are the valves for the water pump. So, there’s still a bit of work to do.
« Last Edit: July 12, 2026, 06:45:35 pm by Michael S. »
Offline Sanjay F
« Reply #52 on: July 12, 2026, 07:57:39 pm »
Its the small details which make the difference and you certainly have them  :popcorn: :ThumbsUp:
« Reply #53 on: July 12, 2026, 07:59:59 pm »
I really like the shapes on the valves.   :ThumbsUp:
« Reply #54 on: July 16, 2026, 08:19:08 pm »
The cylinder sheet is finished—this time made of copper.
Since copper darkens quickly, I used a copper/brass patina solution to help the process along.
« Reply #55 on: July 18, 2026, 05:23:51 pm »
« Reply #56 on: July 18, 2026, 06:37:26 pm »
The patina solution gave it a great color.
« Reply #57 on: July 19, 2026, 05:57:30 pm »
#Invalid YouTube Link#Today I made the two valves for the water pump and then lapped them with fine polishing compound.
I even had time to test with water.
https://youtube.com/shorts/dAwTKqKB29c?is=UwcseQsezHoW0Kwz
« Last Edit: July 19, 2026, 06:03:56 pm by Michael S. »
« Reply #58 on: July 19, 2026, 06:21:46 pm »
Do the valves have springs holding them down, or is it just their own weight?
« Reply #59 on: July 19, 2026, 06:32:45 pm »
Hi Chris, no springs.
The plans don't call for any springs. It looks like it works. I’m not sure which is better, though—ball valves or cone valves, with or without springs.
In any case, this is my first pump using these types of valves.
