Author Topic: Proxxon co-ordinate drilling machine  (Read 599 times)
Offline Team ricky
« on: May 25, 2026, 10:47:58 am »
Here’s a little project to build a good quality drilling machine!
I’ve had the Pf milling head attached to my Pd lathe for a good while and used it mostly for drilling as milling is very hard on the carriage ect …
So I needed a good x y table for a reasonable price, The proxxon one is over £300…… no backlash adjustment, non ball screw ect just hobby grade, not what I was looking for!
I brought a cheap heavy x y table and milled a vertical slot to the rear to mount the head, removed burrs ect and assembled correctly it worked fine :)
The nodd measured good so I carried on and mounted a cheap dro for every day type work, it’s good across 5mm each way , a lot more travel and it’s off by a few percentage, Not that I would rely on one device for bigger distances in any case !
So it’s worked well, around £100 total cost ex the mill head
I’ll get a good amount of use and convince, Hopefully if anyone else has a similar idea thus may help
Offline 55fairlane
Re: Proxxon co-ordinate drilling machine
« Reply #1 on: May 26, 2026, 10:51:35 am »
Interesting build....I cansee where you would need the mill/drill to stand separate from the lathe, must make the workshop more flexible to use
Imagination is much more important than knowledge
