Author Topic: Stuart twin launch  (Read 1870 times)
Offline Team ricky
Stuart twin launch
« on: May 06, 2026, 12:08:22 pm »
Hi Chaps,
I’ve wanted to build a Stuart engine for while so picked up a part built one to have a
go !
So far the machining is good in some areas and bad in others…
The bad first is the crankshaft and probably the reason someone stopped, It apparently was turned between centres looking at the ends but assumption is the mother of all cock ups! It looks to be off set end to end so scrap… the big end journals are different sizes…
I usually make one piece between centres but this one I’m trying a little easier in some ways harder in others build up crank, should be interesting.
I’ve normalised some 303 stainless for the job , this makes it a little harder to work with over steel but the end result is what you want for a marine engine.
Pretty much all the valve gear needed making and fitting
Good bits , pretty much everything else you see ! Made very well when checked amend measured, all threads cut really nicely so not a big set back for me.
I tidied up the paint work pretty much straight away .
Online Sanjay F
Re: Stuart twin launch
« Reply #1 on: May 06, 2026, 03:39:26 pm »
A nice engine in need of some attention, will be following along  :popcorn: :ThumbsUp:
Offline tghs
« Reply #2 on: May 06, 2026, 08:10:56 pm »
looking good,, I have some extra Stuart twin castings that I didn't use when making my navy launch engine..
what the @#&% over
Offline Team ricky
« Reply #3 on: May 29, 2026, 11:35:00 am »
Cheers chaps :)
I’ve fabricated the crank up to completing the silver solder,
All went well, I used 303 precision 8mm, and 2.2mm tapered pins later…
I decided as it was the first soldered crank I’ve made to gently heat everything up below flux melt and held it there for 3-4 mins, then kept a small butane burner on to give background heat , Then used a map gas torch to carry out the soldering, Works well :),
I also pined the webs and journals with copper with the idea if I need to move very slightly any geometry I would have some advantage before soldering! This also worked well and the crank measured well before the heat lol 😂
I fully expect it to move no problem
Next I’m taper pinning the webs via drilling out the copper in each location..
Online Sanjay F
« Reply #4 on: May 29, 2026, 12:11:39 pm »
Nice work, looks like a nice solid crankshaft you’ve made there 👍👍
Offline Team ricky
« Reply #5 on: July 10, 2026, 07:12:03 pm »
Cheers Sanjay ,
Yes it worked out just fine being Silver soldered then pinned….
It all rotates well without slop in the bearings :)
I’m back to where I started and now working on the valve gear
Cheers Ricky
Offline Team ricky
« Reply #6 on: July 16, 2026, 12:16:37 pm »
Here’s a quick video just running on one cylinder,
I’m going to the engine for a while just on one eccentric until I make the reverse gear :)
https://youtube.com/shorts/X27OxDOR1aQ?is=-9aykFO4WOCgOR5j
« Reply #7 on: July 16, 2026, 08:08:30 pm »
It’s already going really well. The other direction of rotation isn't far off now.
Offline Team ricky
« Reply #8 on: July 16, 2026, 08:43:32 pm »
Cheers Michael,
I was surprised it ran as fast as it did just on an airbrush compressor!
Hopefully soon I will machine the second eccentric rod ….
Cheers Ricky
« Reply #9 on: July 16, 2026, 08:50:51 pm »
Hi Ricky
I built the Stuart Compound a while ago and initially experimented with the HP cylinder.
Offline Team ricky
« Reply #10 on: July 17, 2026, 10:18:50 am »
Hi Michael,
Just out of interest as my next engine is the compound version 😁
What did you discover?
Cheers R
« Reply #11 on: July 17, 2026, 10:29:26 am »
I wanted to mention that I also tried turning the engine over for the first few revolutions using only one cylinder.
And without the reversing gear, too.
I modified the engin slightly and built it using metric dimensions.
<a href="https://www.youtube.com/watch?v=WzGeeNbDjPk" target="_blank">http://www.youtube.com/watch?v=WzGeeNbDjPk</a>
« Last Edit: July 17, 2026, 10:34:05 am by Michael S. »
Offline Team ricky
« Reply #12 on: August 03, 2026, 09:14:05 am »
Here’s the engine running on both cylinders and complete for now ;)
Runs on a whiff of air
https://youtube.com/shorts/pXoTFN-Q7o4?is=LnGpzD_YC21rVkpV
Online Sanjay F
« Reply #13 on: August 03, 2026, 09:30:47 am »
Nice one - makes a great sound!  :popcorn: :ThumbsUp:
« Reply #14 on: August 03, 2026, 08:46:48 pm »
Well worth the effort - nice beat  :)  :ThumbsUp:
Per    :cheers:
