Author Topic: Quite small Scotch boiler  (Read 4645 times)
Offline Team ricky
Re: Quite small Scotch boiler
« Reply #15 on: May 07, 2026, 12:58:24 pm »
Here’s a Quick Look at the aluminium cladding :)
It’s going well just one more panel to fabricate ,
I’m just waiting for the stainless cable ties to arrive to hold the cladding in place,
The nice thing with this system its pretty easy to install and remove! Or paint whatever you fancy
Offline Team ricky
« Reply #16 on: May 08, 2026, 02:14:28 pm »
All finished now :)
Aluminium Pannels over lap in the top to bottom orientation so the joins are less visible
It’s just the stainless ties holding everything in place which works well,
If I ever install in boat etc another slimline base would need making as the wooden cradle is a bit chunky
« Reply #17 on: May 08, 2026, 03:33:54 pm »
That is a beautiful little boiler!  :ThumbsUp: :popcorn:
« Reply #18 on: May 08, 2026, 03:38:05 pm »
Came out looking great!  How do the stainless cable ties tighten/fasten in place? Where did you get them?
Offline Team ricky
« Reply #19 on: May 08, 2026, 04:04:57 pm »
Thanks chaps !
A little polish up of the brass to go 😁
The cable ties can be pulled very very tight if needed so they just clamp everything down, upside removal possible fairly easily if needed …
They come from Amazon eBay ect 4.8mm wide and 304 SS
« Reply #20 on: May 08, 2026, 04:12:02 pm »
Just looked them up, never seen the metal 9nes before. Nice!
Offline Team ricky
« Reply #21 on: May 08, 2026, 05:07:14 pm »
Nice 👌
You can get black anodised I guess , Ones too
