Author Topic: Twin cylinder engine  (Read 1859 times)
Offline astroud
« on: February 22, 2026, 01:41:18 pm »
This model was inspired by the Travis design but not wanting to leave well alone I decided to make a few changes. After some thinking I thought I could manage with a single port for both inlet and exhaust and also I could do away with valve springs by having the inlet to the valve block coming in on top of the spool so air pressure on the spool would keep in the eccentric. Then just to be different I used a 90 degree crankshaft.
When it came to the first run it would not keep turning but I could feel the pulses. After a lot of adjustments I bit the bullet and made a new 180 degree crankshaft and a bigger flywheel and now it is a sweet runner.
Now what to do with the first crankshaft  :thinking:
<a href="https://www.youtube.com/watch?v=QejAS9MsrpI" target="_blank">http://www.youtube.com/watch?v=QejAS9MsrpI</a>
Offline CI
Re: Twin cylinder engine
« Reply #1 on: February 22, 2026, 01:59:42 pm »
 :ThumbsUp:
« Reply #2 on: February 22, 2026, 03:05:07 pm »
I like it! Proper chuffing sound and running very sweetly  :ThumbsUp: :ThumbsUp:
Did you make the brass elbow in the supply pipe? I meed to make something along those lines for my upcoming project.
Offline astroud
« Reply #3 on: February 22, 2026, 04:11:35 pm »
Hi Paul
No I did not, I purchased on the bay as a fuel line accessory, it came with barbs to push into flex tubing but I cut those off then drill out to suit the brass pipe.
Same with the T piece at the other end.
Andrew
« Reply #4 on: February 22, 2026, 06:16:02 pm »
Hi Paul
Andrew
Thanks :ThumbsUp:
Offline Chipswitheverything
« Reply #5 on: February 23, 2026, 09:15:13 am »
This is a very neat and compact little engine that runs sweetly, nice ...  Commiserations on having to remake the crankshaft, but was worth it .     Dave
