Author Topic: Metropolitan Railway Electric Locomotive  (Read 3383 times)
Offline mikemill
« on: November 10, 2025, 09:46:19 AM »
These locos were introduced in 1920’s to run overground from Baker St to Amersham pulling standard coaches. They were known as Growlers due to the noise made by the traction motors. I can remember seeing one at Baker St in the 1960’s.
The model is mostly 3D printed with full interior cab detail; the bogies have a steel chassis to carry the motor/gearboxes with printed detail plate sides, both bogies are powered.
The model was created in collaboration with Paul Smith from FK3d.co.uk who made the laser resin prints, this process produces perfectly smooth surfaces and renders remarkable detail.
We are considering making the loco available as a kit if there is any interest.
Offline samc88
Re: Metropolitan Railway Electric Locomotive
« Reply #1 on: November 10, 2025, 03:44:53 PM »
That looks really nice Mike, the early electric and diesel locomotives are really interesting, what scale is it? Will you be painting it?
Offline Chipswitheverything
« Reply #2 on: November 11, 2025, 08:22:37 AM »
This is making a very fine model of a characterful engine, is this to your usual Gauge 1 ? larger scale for electric powered locos?   Will look rather splendid when finished in the rich livery of the prototype.  Dave
Offline mikemill
« Reply #3 on: November 11, 2025, 09:46:59 AM »
Sam & Dave ( a well known soul duo from the 60's)
Thank you for your kind comments, the loco is build to G3 2.5in. I am in the process of painting the loco.
Will post image when competed.
Offline wagnmkr
  • Lindsay, Ontario, Canada
« Reply #4 on: November 11, 2025, 10:30:41 AM »
That will be a stunner when painted!  The print quality is the best I've seen.
Tom
Offline mikemill
« Reply #5 on: November 12, 2025, 01:01:42 PM »
The loco is complete, as there are two motors one for each bogie I have used a lead acid battery for extra power, the battery is located in the middle of the body and gives extra weight for good traction.
I would like to add sound but no idea how to make the sound of a Growler, any ideas.
« Reply #6 on: November 12, 2025, 04:17:16 PM »
A Stunning result (looks almost too new) and a fitting homage to one of the Electric Science early Pioneers  :praise2:   :praise2:
Per       :cheers:
Offline Zephyrin
  • near Paris, France
« Reply #7 on: November 14, 2025, 09:58:58 AM »
beautiful model of a very appealing loco, and at 2.5" gauge she makes an impressive model.
« Reply #8 on: November 15, 2025, 07:08:49 AM »
Very nicely done  :praise2: At 2.5" gauge that must be quite a size and weight.
Offline mikemill
« Reply #9 on: November 15, 2025, 10:09:59 AM »
Thanks for the kind comments. The loco is 20in long and weighs 8Kg.
With metal bogie chassis, a 1mm steel plate under the footplate I was getting wheel slip, so I added a lead acid battery which adds extra weight, gives plenty of power and long running time. Now runs well
Offline samc88
« Reply #10 on: November 15, 2025, 09:38:06 PM »
Really nice work. What did you use to paint it, is it airbrushed?
« Last Edit: November 15, 2025, 09:45:48 PM by samc88 »
Offline mikemill
« Reply #11 on: November 17, 2025, 02:55:31 PM »
Sam
I used a spray can with a RAL code 3003, mixed by a firm on ebay
