Author Topic: Mercedes or BMW Inline-6 Info  (Read 5228 times)
Offline petertha
Re: Mercedes or BMW Inline-6 Info
« Reply #75 on: January 09, 2026, 05:45:16 PM »
Thanks Mike. As Jason mentioned I did see the Diii pictures from thevintageaviator web site. And I came to much the same conclusions you summarized - specific to that model/engine. The picture shows the hole saw cutting through the jacket in the head area, surely that means fluid communication to the cylinder jacket annulus. And so the water circulation goes exactly as you described. Now there is no guarantee what Mercedes did is exactly was what BMW did, but I took this to be a good guiding principle in the absence of any other information. In fact as I thumb through my new books there appear to be slight water piping variations even among same engine brands/models, but that would make sense based on what airframe they resided in & different radiator locations.
What gave me pause to above understanding, which I posted a bit later in #8, was an excerpt from Airplane Engine Encyclopedia specific to the BMWiii. Here it is again. 'the centrifugal pump has two outlets, one leading to the bottom and one leading to the top of the end cylinders. All of the cylinder water water passages are connected together'. two outlets, that seems specific. Is this something something different to the Diii or a wording issue? This is what confused me, not the Diii. But when I look at the BMW pump pics from other documents I don't see anything obvious suggesting a second outlet at least integrated in the pump. So my guess is maybe a wording issue in the Encylopedia because I have never come across any similar elsewhere.
As mentioned, although I'm interested, I'm not particularly fussed if I ever know the BMWiii nuance, presuming there even was a nuance specific to the model. Its pretty much a given I will have no water in the head, it will be confined to the jackets. Flooding the jackets in parallel from a lower tube & collecting them in an upper tube will hopefully get the cooling job done and somewhat resemble FS in spirit. Thanks for your interest.
Offline petertha
« Reply #76 on: January 09, 2026, 06:23:05 PM »
Looks like these BMW runup videos need to be played off the website (not on YouTube). Scroll down towards the page bottom.
https://www.memorial-flight.com/fokker-dvii?lang=en
Offline Fj45
  • 11hrs early
« Reply #77 on: January 09, 2026, 11:32:22 PM »
 Hi Peter,
 l'm convinced you hit the nail right on the head by calling it a "wording issue" in the encyclopedia. There's clearly only one outlet on the pump. The two outlets they miss-refer to are on the black 'f' shaped vertical pipe leading up from the pump.
 Why BMW chose to have two is a mystery to me, the Merc, the Fiat and my car (oddly a BMW) all make do with one.
 As long as your water enters at the bottom and exits at the top it will do it's job.
Your pump will then not have to fight the thermosyphon effect, rather they will work together.
Regards ... Brett
