Author Topic: 2.5" Gauge Green Arrow Build  (Read 14374 times)
Offline stevendavis
Re: 2.5" Gauge Green Arrow Build
« Reply #60 on: January 21, 2026, 06:15:26 PM »
Here's the parts for the lubricator so far. I still need to make the arm and ratchet pawls. I tested the assembly and it does pump oil. I will probably make a new check valve, as I didn't leave enough room for the fitting nut under the tank.
If you want to see my super power, pull my finger!
Offline stevendavis
« Reply #61 on: February 06, 2026, 05:58:46 PM »
Had some time over the last few weeks to get more done on the Lubricator. I used a print from the Rob Roy book to make the pals, and filed them to shape. I need to look for some smaller springs for it, as the ones I have on it now are a bit bulky. Though it is working ok. Still need to make a lid of some kind and add the mounting flange.
« Reply #62 on: February 06, 2026, 10:23:25 PM »
Very interesting little ratchet mechanism!  :ThumbsUp: :popcorn:
And your pawls came out great!
Offline stevendavis
« Reply #63 on: February 07, 2026, 12:43:48 AM »
Thanks Kim!
Offline stevendavis
« Reply #64 on: February 11, 2026, 03:31:01 AM »
Quick update on my channel.
<a href="https://www.youtube.com/watch?v=mdzyVXzEHCw" target="_blank">http://www.youtube.com/watch?v=mdzyVXzEHCw</a>
Offline stevendavis
« Reply #65 on: March 07, 2026, 04:00:50 PM »
Had some time to get a little work done on the Green Arrow. Got the crank pins hardened and locktited in. Wheels painted and one side of the axles locktited in. Still need to quarter the wheels.
Offline stevendavis
« Reply #66 on: March 07, 2026, 06:11:35 PM »
Plugged some numbers into Cad and this is what I think is right. The bottom line is my carrage surface on the lathe. I'll be quartering on the lathe between centers.
« Reply #67 on: March 07, 2026, 07:41:22 PM »
Those wheels look great when assembled  :ThumbsUp:
Offline stevendavis
« Reply #68 on: March 07, 2026, 07:55:34 PM »
Thanks Paul.
« Reply #69 on: March 07, 2026, 11:53:14 PM »
So, based on the drawing you attached, your quartering is actually thirding? 120 degrees?
And why are they all set to 120?  Why is one 126 and one 114 degrees?
Very interesting,
Offline stevendavis
« Reply #70 on: March 08, 2026, 03:35:29 AM »
Yes, the center cylinder is at a 6* down angle compared to the outer cylinders. From what I understand that angle makes it necessary to clock the wheels at 120, 126, and 114. If I'm wrong on that, I hope someone will chime in.
« Reply #71 on: March 08, 2026, 04:12:56 AM »
Ah!  Makes sense!  Excellent explanation, thank you!
Offline stevendavis
« Reply #72 on: March 10, 2026, 01:15:20 AM »
I've been hesitant to do the wheel quartering, but I got it done. Hope it's all good.
<a href="https://www.youtube.com/watch?v=FKaJMJ4YsX0" target="_blank">http://www.youtube.com/watch?v=FKaJMJ4YsX0</a>
Offline stevendavis
« Reply #73 on: March 16, 2026, 01:36:19 PM »
Took about a day to get the coupling rod jig made up and about another day of adjusting to get the wheels rolling as smoothly as possible. It was back and forth for a bit.
<a href="https://www.youtube.com/watch?v=H1YCIt-WQ7g" target="_blank">http://www.youtube.com/watch?v=H1YCIt-WQ7g</a>
