Author Topic: 2.5" Gauge Green Arrow Build  (Read 14369 times)
Offline stevendavis
« on: October 22, 2025, 04:42:59 AM »
Been working on this project for a little while now. Lost a few months due to an injury, but starting back up. The boiler showed up, made by Western Steam. Cost way more than expected due to the exchange rate and tariffs now imposed on UK products. Boiler looks great though. They did a wonderful job on it. I've also got the crank pins done, and the eccentric for the lubricator. Still have to harden the pins and paint the wheels before I do the clocking.
If you want to see my super power, pull my finger!
Re: 2.5" Gauge Green Arrow Build
« Reply #1 on: October 22, 2025, 05:02:40 AM »
Sorry about the extra expense, but it sure is a pretty-looking boiler!   :ThumbsUp: :popcorn: :popcorn:
Offline stevendavis
« Reply #2 on: October 22, 2025, 12:53:07 PM »
They did a really good job on it for sure.
I'm starting to work on the cylinders some and didn't want to make mistakes, so I poured a test cylinder and steam chest, but after doing some initial machining, it was unusable. I'll probably try again. Looks like some gasses escaped through the sandcore area and up through the port face. I did however make sure my setup was solid to start on the supplied castings.
Offline stevendavis
« Reply #3 on: October 22, 2025, 01:18:39 PM »
One question I do have is with this being a 3 cylinder engine, do all three need to be 120* out from each other? The prints show the leading and trailing at 120, but no detail on the driving. Thanks
« Reply #4 on: October 22, 2025, 02:33:54 PM »
Had to look up that engine, I never knew they did 3 cylinder locomotives like that. Was that engine unique, or was that a fairly common thing?
Offline Charles Lamont
« Reply #5 on: October 22, 2025, 02:50:16 PM »
Like what? I am not sure what you are asking.
« Reply #6 on: October 22, 2025, 02:55:06 PM »
Having a third cylinder in the center of the frame, rather than just one either side in line with the driving wheels.
  • Oregon
« Reply #7 on: October 22, 2025, 03:08:21 PM »
I find the Green Arrow to be a very handsome locomotive, and yours appears to be coming along great. I keep a digital copy of Martin Evans' Model Engineer build series for a gauge 1 version, just in case...
Offline uuu
« Reply #8 on: October 22, 2025, 03:55:28 PM »
There were quite a few three cylinder designs in the UK.  And a few in other countries.  The challenge on many types was not how to connect the crank of the middle cylinder, but how to drive the valves.  There were "conjugated valve gears", using the motion of the valves of the two outside cylinders in combination to drive the middle one.  Here's an article on one such system:  https://en.wikipedia.org/wiki/Gresley_conjugated_valve_gear
Wilf
« Reply #9 on: October 22, 2025, 03:58:12 PM »
Wilf
Thanks Wilf!
« Reply #10 on: October 22, 2025, 04:12:54 PM »
Crueby - apart from the weird and wonderful configurations of the earliest locomotives, most British locomotives before 1900 had two inside cylinders. Two outside ones gradually became more normal after that.
The early three cylinder engines were mainly compounds, with either 2 outside HP cylinders feeding one large inside LP cylinder, or, much more commonly, a single inside HP feeding two outside LP cylinders.
 Simple expansion 3-cylinder and 4-cylinder locomotives started to appear about the turn of the century. Three cylinders were quite common in larger engines, while the four cylinder arrangement was mainly applied only to the largest express designs. The LNER, LMS, and Southern railways used 3-cylinder locomotives extensively, while I am not aware of any on the Great Western.
https://kesr-mic.org.uk/resources/The+Modern+3-Cylinder+Locomotive.pdf
Offline stevendavis
« Reply #11 on: October 22, 2025, 04:39:40 PM »
Thanks Charles!
That resorce is showing that I need to clock the center crank at 114*, as the center cylinder is offset 6*. I'll give that a go. The little book says to possibly wait until your ready to time the valving, but I don't see how I can properly build the conecting rods without setting the wheels first!
Yep,
The outside motion moves the inside valve by way of combination levers.
« Last Edit: October 22, 2025, 04:49:54 PM by stevendavis »
« Reply #12 on: October 22, 2025, 05:34:44 PM »
Wow! This certainly fits in the "Learn Something New Every Day" category!  I had never heard of 3-cylinder steam locomotives!  This is very fascinating. Thanks for the links. Interesting reading.
« Reply #13 on: October 22, 2025, 07:05:11 PM »
Many of the Shays were 3 cylinders, no compounding, those were easy to see since tgey were hung together on one side. Having a compound third should give a nice steam savings. Thanks for the info!
« Reply #14 on: October 23, 2025, 04:50:26 AM »
True, I knew about the Shays. Thanks for mentioning that Chris.  I guess it was the non-geared locomotives with 3 cylinders - two on the sides and one in the middle - that were new to me! :)
