Author Topic: Make a pulse jet engine 1958 plans  (Read 3576 times)
Offline AlexS
« on: October 21, 2025, 02:42:30 pm »
Anyone build someting like this small pulse jet engine?
Nowadays with 3d printing an cnc should be interesting too!
https://www.instructables.com/Make-a-Pulse-jet-engine-Scanned-from-1958-plans/
Re: Make a pulse jet engine 1958 plans
« Reply #1 on: October 21, 2025, 03:13:42 pm »
I remember those plans from when they first came out. :old:     Wanted to build one at school during metal work lessons, but never allowed to. :ThumbsDown:
If you did build one, they were notoriously difficult to start, without a large volume, compressed air supply. If you did succeed, they were extremely LOUD. The tail pipe glowed red hot, so they were also deemed to be an extreme fire risk; free flight or radio controlled flying of any pulse jet is banned in UK, due to the fire risk to both property and crops.
Would be a fun project.
« Last Edit: October 21, 2025, 04:35:44 pm by Vixen »
« Reply #2 on: October 21, 2025, 04:00:42 pm »
Order replacement eyebrows first!
« Reply #3 on: October 21, 2025, 04:09:15 pm »
You will be popular with your neighbours if you run it  :lolb:
Offline Sanjay F
« Reply #4 on: October 21, 2025, 06:06:05 pm »
I remember Scrapheap challenge and Junkyard Wars in the US had episodes where they built similar jet engines.......they worked well, looked amazing and a good way to lose your hair!!  :Lol:
« Reply #5 on: October 21, 2025, 08:58:54 pm »
Colin Furze has made several fairly large sized versions on his YouTube channel.   :popcorn: :ThumbsUp:
Offline AlexS
« Reply #6 on: October 22, 2025, 08:52:52 pm »
Yeah there is also one called crazy rocket man. If I understand he use a mix of propane and diesel to cool combustion temperature.
After reading, I don't want to be bolt to early or deaf(or neighbours).
Well, at work we are thinking of adding two jets om each side of a small pitbike if only for looks.
I saw a video of JohnnyQ90 (recent one) similar size. Started quit easy with a simple foot air pump.
<a href="https://www.youtube.com/watch?v=1LimWlYIhjw" target="_blank">http://www.youtube.com/watch?v=1LimWlYIhjw</a>
Well, let first finalize some other projects!
« Reply #7 on: October 22, 2025, 09:06:24 pm »
Yikes! I'm sticking with my little steam engines!   :paranoia:
Needs a side tube to Y in partway down the exhaust, to feed in the tennis balls...  Put one across the bay!
Online AVTUR
« Reply #8 on: October 22, 2025, 11:12:54 pm »
As a student I did a lab test on a Westlands pulse jet that would have been put on the tip of a helicopter rotor blade. The duct was about 5 feet long. It was terrifying. In addition to everything said it ran at around 100 Hz and resonated one's body cavity.
A basic problem with the pulse jet is that as the forward speed increases the inlet duct starts to resonate causing the thrust drops.
I never want to see another one but they are interesting.
AVTUR
