Author Topic: blow down.  (Read 8322 times)
Offline London_lighterman
blow down.
« on: August 02, 2025, 07:07:43 pm »
A very good evening from London Uk.
I wonder could the panel give some advice on loco boiler blowdown valves.
I know there is much written and murmured about the use of brass in boiler fittings, and case in point the ones I have just extracted from a loco were close to dust, strangely not much at the wet end in the bushing but the body of the valve.
I see that a lot of the commercial fittings are brass and while its a much nicer material to work with I would like some thoughts on a combination of materials IE  gunmetal shank go into the bushing in the outer wrapper and seat for the ball and brass body. stainless valve spindle...
Am I building a Frankenstein with possible galvanic tendencies?
Thanks in advance.
Re: blow down.
« Reply #1 on: August 02, 2025, 07:53:54 pm »
For the small amount of material involved I would just use bronze or GM for the whole body.
Stainless is OK for the spindle and you can just have a chamfer on that directly onto the seat so no need for a stainless ball.
There are grades of brass that are classed as DZP Dezincification Proof but harder to come by in our small quantities.
Re: blow down.
« Reply #2 on: August 02, 2025, 08:06:09 pm »
Getting the proper bronze would be the way to go.   I mean think of the time you spend on making it.     The material is the cheap part, and the right material .   (Tobin Bronze?  Gun metal?   What ever your local model boiler code says)   makes the job a lot safer...
Re: blow down.
« Reply #3 on: August 02, 2025, 08:19:38 pm »
Thank you.
I will re think the idea.
always a pleasure bringing my questions to a knowledgable mess room.
