Author Topic: OKMO Harley - Davidson Panhead V-Twin Engine Model R30  (Read 2401 times)
Offline Jim
  • South Coast of New South Wales, Australia
    • Blue Heeler's Model & Toy Steam Engine Room
« on: June 06, 2025, 02:35:35 am »
An absolute delightful (gasoline) petrol engine from OKMO Microcosm the level of detail in the engine is incredible for the size,
This is a miniaturised version of the Harley - Davidson Panhead engine, it is scaled down by 1:5, and the details of each part are truly representative.
The engine is 120MM long, 90MM wide, 110MM high and 1.1kg in weight and the displacement is 4.2ML.
The engine cylinder diameters are 13MM, and the stroke is 16MM. The fuel is petrol with oil added (gasoline). The igniter for the spark plugs uses three 1.5V small batteries (4.5V) for power supply.
This is a rather complex model, which is made of aluminum alloy, brass and stainless steel CNC.
This one of the most complex engines that OKMO Microcosm produce and manufacture.This is a very representative V-type dual-cylinder engine with an included angle of 45 degrees.
Panhead (1948~1965) The 1948 FL was unveiled with a new "Bontou" engine and the nickname Panhead which comes from the engine cylinder head (rocker covers) resembled cooking pans.
<a href="https://www.youtube.com/watch?v=X0ytnPBtrrY" target="_blank">http://www.youtube.com/watch?v=X0ytnPBtrrY</a>
Kind regards,
