Author Topic: Construction Crane Paul Borde 1867  (Read 9232 times)
Offline Giraldus
« on: May 28, 2025, 05:04:16 pm »
Hi all,
a visit to Paris was at the beginning of this model. In a display cabinet of the Musée des Arts et Metiers I found Inventory No 7737. The text is basic: Machine for lifting materials by Borde. As provenance the World Exhibition Paris 1867 is given:
At first I did not find more information. When I found out that “Borde” was a proper name and Monsieur Borde had the given name “Paul”, more information showed up:
In 1856 the port of La Joliette in Marseille was transformed by a huge property development masterminded by the financier Jules Mirès. The engineer and builder Paul Borde was contracted to undertake this project on a very short schedule. Only mechanisation could enable the rapid and precise positioning of materials and save on scaffolding. To achieve this, Borde invented a steam-powered crane on rails running parallel to the facade of the building under construction. Materials could be deposited anywhere on the construction by varying the angle of the crane’s pivoting boom. Only two men were required to operate the machine. The success of this project won Borde other major contracts in Marseille and then Paris. His lifting apparatus was patented and gradually improved. This scale model, bought by the Conservatoire after the Universal Exposition in 1867, is probably the final version of this machine.
The model’s scale was given here with 1:20. Finally I found that the boom had a total length of 20 m and that the pivot was 18 m above ground.
In a contempory magazine published 1859 three cranes can be seen at work:
Obviously these cranes are earlier versions than the one in the World Exposition 1867.
I had taken quite a few photos in the museum, but in the end I had to take a step back from them to get a working model. The 1867 model has some missing parts, others most likely have been added later. I doubt that the model was a working model - I think it has been used to give potential clients something to look at.
My model is in scale 1:20. It is powered by air and has the same functions as the original crane. The load may be hoisted and lowered and the crane with the load may travel on the track along an imaginary building. The single cylinder engine may have to be started manually. A slip excenter is used to change the engine’s rotation direction. A simple brake is used to fix the load when the operator wants to change from hoisting to lowering. The tilt of the boom may be changed manually.
Occasionally I have been asked if the crane might tip over. Yes - he can. Presumably quite like the original. There is evidence that at least smaller cranes back in the days have been clamped to the rails. If this has been the case here - I am afraid we will not find out more than 150 years later.
If you want to see it in action:
<a href="https://www.youtube.com/watch?v=t_1-97v6Tro" target="_blank">http://www.youtube.com/watch?v=t_1-97v6Tro</a>
The load is a small brick. It’s weight would have been 1,3 t in 1:1.
So long for now
Gerd
P.S.: Check my website at https://balancier.eu/Crane-Beta-en for references.
« Last Edit: May 30, 2025, 11:17:24 am by Giraldus »
Re: Construction Crane Paul Borde 1867
« Reply #1 on: May 28, 2025, 06:09:12 pm »
Wonderful models! Thats a great mechanism, makes a lot of sense for building construction. I like the design of that engine, with the extended piston rod to act as a crosshead/guide. Well done!
« Reply #2 on: May 28, 2025, 06:18:49 pm »
Very nice!
Thanks for sharing.
Offline kuhncw
« Reply #3 on: May 28, 2025, 06:53:33 pm »
Very well done. Interesting model.
Chuck
Online Sanjay F
« Reply #4 on: May 28, 2025, 08:16:42 pm »
Amazing, to think you got saw it in a museum cabinet first of all then went on to build it, very well done, it looks and operates superbly
Offline pirmin
« Reply #5 on: May 28, 2025, 09:02:33 pm »
what a nice Model! the Technisches Museum in Wien / Vienna also owns a lot of models, i will see if i can make pictures the next time i am there. there was also a crane
Offline Jack
« Reply #6 on: May 28, 2025, 09:46:10 pm »
I visited that museum last year while on a visit to Paris France, after someone on here recommended that I see it while in Paris. It was full of just about everything that has been invented, If it was small enough the real thing was there  and if not there was a model of it. I spent the entire day there and thoroughly enjoyed it. I must have taken hundreds of pictures until my phone was full. Besides all of the other things that one must see in France this was certainly a highpoint for me.
Thanks for reminding me of my visit.
Jack
« Reply #7 on: May 28, 2025, 10:00:25 pm »
Very nice, thanks for sharing the photos/video.
« Reply #8 on: May 28, 2025, 10:40:12 pm »
Very cool model, thanks!  :ThumbsUp:
Offline Zephyrin
  • near Paris, France
« Reply #9 on: May 28, 2025, 11:29:00 pm »
great model that works very well, very original too, congratulations !
nice models also on your website !
« Reply #10 on: May 29, 2025, 12:31:43 am »
Very neat model!  :ThumbsUp: :popcorn:   Fascinating choice of models for sure.  Thanks for sharing it!
« Reply #11 on: May 29, 2025, 07:54:24 am »
Excellent  :praise2: Thank you for sharing that with us  :)
Offline Giraldus
« Reply #12 on: May 30, 2025, 11:23:57 am »
Hi all,
thanks for your feedback.
I happened to find a good modern picture of the docks of Marseille, where Borde's cranes where used:
https://www.marseille-tourisme.com/en/discover-marseille/culture-heritage/discover-the-sites-and-monuments-in-marseille/les-docks/
Kind regards
Gerd
