Author Topic: Philip Duglos Oddball Hit &Miss six Stroke Engine  (Read 5853 times)
Offline Bruno Mueller
    • My Homepage
« on: May 06, 2025, 07:47:35 pm »
I took the drawings for this engine from Philip Duclos' book “The Shop Wisdom”.
I converted the dimensions to the metric scale and changed them slightly.
I have already finished the first parts.
http://mueller-bruno.de/  http://www.bosch-combi.de/   https://www.youtube.com/@Jailguzzi
Whoever talks shit about me behind my back is in the best position to lick my ass.
Greetings from the southwest of Germany.
Re: Philip Duglos Oddball Hit &Miss six Stroke Engine
« Reply #1 on: May 06, 2025, 08:31:28 pm »
Looks like a great start!
But, six stroke? How does that work?   :thinking:
Online Sanjay F
« Reply #2 on: May 06, 2025, 08:32:15 pm »
I just wondered that - I found this video, but doesn't explain the 6 strokes?
<a href="https://www.youtube.com/watch?v=81wEKaSo6wM" target="_blank">http://www.youtube.com/watch?v=81wEKaSo6wM</a>
« Reply #3 on: May 06, 2025, 09:05:33 pm »
Did a bit of searching on 6 cycle engines - what I found was that they take an extra revolution and fire a second time to more completely burn some un-burnt gasses left in the cylinder from the main firing. So, it does intake/compress/fire/exhaust on the first two revolutions, then compress/fire again on the third revolution, then starts over again. An old concept that does work, more efficient, but with a little less overall power. Interesting!
Online Sanjay F
« Reply #4 on: May 06, 2025, 09:38:19 pm »
I have enough trouble with 2 strokes, let alone 6! I have the similar problems with 7 string guitars!
I like the engine though, a wonderful chugging noise, I'm intent on building a hit 'n' miss in future just for that  ;D
Online Roger B
« Reply #5 on: May 08, 2025, 11:12:14 am »
Looks to be a fun project, I will be following along  :)  :)  :wine1:
I guess that this design allows for extra expansion of the fuel mixture, which gives a similar effect to the Atkinson cycle  :thinking:
Offline wbernhard
  • Jr. member
« Reply #6 on: May 15, 2025, 05:28:19 pm »
Regarding the answer from "crueby"
"Did a bit of searching on 6 cycle engines - what I found was that they take an extra revolution and fire a second time to more completely burn some un-burnt gasses left in the cylinder from the main firing. So, it does intake/compress/fire/exhaust on the first two revolutions, then compress/fire again on the third revolution, then starts over again."
After looking at Phillip Duclos's drawings, my conclusions are as follows:
Based on the shape of the exhaust valve cam and the crankshaft-to-camshaft ratio of 3:1, I conclude the following:
The engine simply makes an additional third revolution with the exhaust valve open. With the exhaust valve open, it can neither draw in nor generate compression. It won't fire a second time either! Why should it?
Best regards, Charly
Offline rdean33422
« Reply #7 on: May 15, 2025, 09:33:54 pm »
This is my 6 cycle double acting engine I completed a while back.
<a href="https://www.youtube.com/watch?v=jmu07b3MqHA" target="_blank">http://www.youtube.com/watch?v=jmu07b3MqHA</a>
It does operate like Charly said but it does suck in air and blow it out during the 5 and 6 cycles..
Ray
    • My Homepage
« Reply #8 on: May 16, 2025, 01:04:26 pm »
I made the next parts.
The bronze bushings are due to arrive next week.
I still have to make the crank bolt.  The crankshaft axles made of 1.7225 (42CrMo4) were pressed in with Loctite 638.
I plan to start the engine with a round pulley and starter cord. That's why there are no claws on the flywheel axle.
After the two flywheels were finished, I had to clean the lathe and the surrounding area from the gray cast iron dust.
« Last Edit: May 16, 2025, 01:21:00 pm by Bruno Mueller »
