Author Topic: Bore gages  (Read 5856 times)
Bore gages
« on: April 22, 2025, 09:21:57 pm »
Just picked up 2 sets of bore gages.     One 0.4" to 0.7" and the other 1 to 1.75   Both to "tenths"    In addition to the bore tri mike that sits in the middle of the range for the bores on the 917....I think I have the measurement part sorted out.  Can't make what you can't measure right?
It's a start....bought used off the bay after some searching....got a great price on them!
« Last Edit: April 22, 2025, 09:56:13 pm by steamer »
Re: Bore gages
« Reply #1 on: April 22, 2025, 09:36:42 pm »
Nice!  Very handy tools - I got a more modern cheap version a while back, looks like same mechanism and sets of accessory fittings, though yours looks like a nicer set. Perfect for both measuring the bore as well as checking it to be parallel.
Re: Bore gages
« Reply #2 on: April 22, 2025, 10:27:44 pm »
Hello Dave,
Nice, you had a good win there. Did you get or have you got the calibration rings which allow you to make absolute measurements.
I have a nice Mitutoyo three point but no calibration ring (yet). So for now, it is used for comparative measurements only.
Re: Bore gages
« Reply #3 on: April 23, 2025, 12:41:07 am »
Hello Dave,
Working on those now.....15mm and 32 mm are high on the list....thow both can be set to a micrometer for comparative work   I have a .846 ( 21.5mm) one already...amazingly
Re: Bore gages
« Reply #4 on: April 23, 2025, 06:13:20 pm »
Lovely devices, should work a treat.  We have a 3/4" range hole mic (Mitutoyo 3-pt) that is lovely for one of our more precision bits of valve trim here at work, but the price of those makes me swallow hard every time I pick it up.
Re: Bore gages
« Reply #5 on: April 24, 2025, 01:02:47 am »
I have a tri mike but with a much more narrower range, and even used they're expensive!    But It's NICCCCCCCCE!!!!!    I bought this one about 3 years ago for measuring the bores on the 917 build, with a ring gage to match.
Picked up this Blade mike for piston ring grooves specifically....it's got a touch of light rust here and there, but that will clean up.
« Last Edit: April 24, 2025, 01:26:26 am by steamer »
Re: Bore gages
« Reply #6 on: April 24, 2025, 01:11:58 am »
And I found some ring gages!
32mm  -.0002"
and
15mm
They appear good, and the seller guarantee's they'll check out.
Re: Bore gages
« Reply #7 on: April 24, 2025, 07:59:58 am »
Expensive Toys Tools - Always nice to have  ;D
Regarding calibration - I remember our Physics Teacher telling a story about Swedish Gauge Blocks and Ford Motor Company.
Ford bought yet a good amount of Gauge Blocks (for a new department) and they complained that they where NOT to Specs.
So the Manufactor got them back and did a Thorough Inspection and they where much better than promised => back to Ford.
Ford Inspected them again and found the same errors as before => send them to Sweden again. Repeat repeat ....
So when Ford complained the third time - one of the Swedish Engineers suddenly got suspicious and asked what the temperature was in Fords new Laboratory ..??
Reply - a constant 25C ....
Aha - Please read the Spec-sheet or look at the Box : Calibrated and should be used @ 20C !!!!
I hope that your new Rings are good and accurate Dave  ;)
Per         :cheers:
Re: Bore gages
« Reply #8 on: April 24, 2025, 03:13:19 pm »
Well   all the tools I bought are lovingly  pre owned which goes for 98% of my equipment.    Ring gages were $40 shipped....but it is nice to have....
Re: Bore gages
« Reply #9 on: April 24, 2025, 03:32:56 pm »
It all falls.under the heading of if I.cant measure it   I can't make it.....
