Author Topic: Vacuum chuck ..  (Read 2468 times)
Offline Brian U
Vacuum chuck ..
« on: April 12, 2025, 08:23:54 PM »
Long over due project for holding engraving stock to make name plates, etc. Tired of the tape and glue method or double face tape.
Used material I had on hand. Aluminum base and steel top. Worked out to 6 3/8" wide x 8 3/4" long and 2" high.
I use painters tape to block any holes not needed around part.
Re: Vacuum chuck ..
« Reply #1 on: April 12, 2025, 08:57:05 PM »
That's really nice.
Offline redhouseluv
Re: Vacuum chuck ..
« Reply #2 on: April 12, 2025, 08:59:07 PM »
That's very clever, I like it!  :D
Re: Vacuum chuck ..
« Reply #3 on: April 12, 2025, 09:35:34 PM »
Hello Brian,
That's a useful looking vacuum plate you have made. Ideal for engraving parts.  :ThumbsUp: :ThumbsUp:
What vacuum pump do you use? And what is the max vacuum in can draw in inches Hg ? I have found painters tape is not imperious, i.e. weeps small quantities of air. Better if you can find some pure aluminium tape.
Offline Brian U
Re: Vacuum chuck ..
« Reply #4 on: April 13, 2025, 02:52:22 AM »
Hello Brian,
Hi Mike,
I have a surplus industrial Gast vacuum pump and get probably 25 + inches of vacuum. I double layer the painters tape. It creates no mess when removing.
Having a flat and parallel surface is a must since some cutting depths are sometimes less than .010" deep.
