Author Topic: Brian Perkins - unfinished projects  (Read 5492 times)
Offline jerry Perkins
  • Jr. member
« on: April 06, 2025, 01:18:35 pm »
Hi. My late Father,  Brian Perkins, left a couple of unfinished projects. Members may be aware of these as Dad was an active member of this and other model communities.
The projects are the 1/4 scale Aquila engine which was the twin of that featured on the cover of the attached
Christies catalogue and the 1/3 scale model of the Mercedes W165 featured in Dads website.
https://web.archive.org/web/20201022182229/https:/sites.google.com/site/brianperkins87/home
We're looking to pass these on to a good home. Please let me know if you'd be interested in receiving more information.
Jerry Perkins
Re: Brian Perkins - unfinished projects
« Reply #1 on: April 06, 2025, 02:51:40 pm »
Hi Jerry
Can't say that I've seen your father post here on this forum .... But he might have had a look on Mikes (Vixen) build :
https://www.modelenginemaker.com/index.php/topic,5142.1140.html
Look @ second post down. He has also build a number of other amazing model Engines.
But he will have to chime in himself.
Best wishes
« Reply #2 on: April 06, 2025, 04:09:49 pm »
Hi Jerry,
Last time I saw your Dad was at the Bristol show in 2018. There are some pictures of our (ICEBG) engines on the stand here: https://www.modelenginemaker.com/index.php/topic,8301.msg180792.html#msg180792
We have a number of photos of his engines on the forum. Here are some more from 2015: https://www.modelenginemaker.com/index.php/topic,5211.msg99812/topicseen.html#msg99812
We still miss your Dad, he was always generous with sharing his knowledge and helping others make their own model engines.  :)
Online Sanjay F
« Reply #3 on: April 06, 2025, 04:55:27 pm »
I never knew your dad, but looking through the pictures he was clearly a very talented engineer. The models definitely need to go somewhere where they can be appreciated and finished
« Reply #4 on: April 06, 2025, 05:55:51 pm »
Hello Jerry
I first met your Dad, Brian, 25/30 years ago. He had just started building the two 1/4 scale Aquila sleeve valve engines and I was about to start on my 1/4 scale poppet valve Bristol Mercury. Brian said " Why not build two at the same time, once you have the tooling and fixtures made, you may as well make a second part; it's only a little extra work. That's what I am going to do with the two Aquila's".
I fell for it, hook line and sinker and two Bristol Mercuries started to take shape. I soon realised the folly. Doing an extra crankshaft or crankcase was quite straightforward, but the second engine meant an additional 36 valves, valve guides and rocker gear. etc.  :Doh:
One of Brian's Aquila engines went on to win a much converted MEX Gold medal at Sundown and the Duke of Edinburgh Challenge Trophy (reserved for the cream of the cream) the next year. I believe a Spanish engine collector bought the first Aquila engine shortly afterward. As I understand it, the second engine was never completed (assembled), however the parts for the second Aquila are more or less complete.
Good luck with finding a good home for these two amazing projects.
« Last Edit: April 06, 2025, 06:01:21 pm by Vixen »
