Author Topic: Mount Trapezium  (Read 15350 times)
Online uuu
Re: Mount Trapezium
« Reply #60 on: April 14, 2025, 08:00:35 PM »
What's that little notch on the opposite side for in your photo Wilf?
It's for the condensate drain.  Drain cocks operated from the loco cab.
Wilf
Re: Mount Trapezium
« Reply #61 on: April 14, 2025, 08:30:40 PM »
Wilf
Ah I see, thanks.
Offline redhouseluv
Re: Mount Trapezium
« Reply #62 on: April 14, 2025, 08:37:12 PM »
Thanks all  - my inexperience of such things and the 'fear' as Paul calls it is making me both cautious & nervous!
Yes, I can see 1, 2 and more holes are normal, I'd just never come across it before, this is how close I was before I stopped  ;D.
Re: Mount Trapezium
« Reply #63 on: April 14, 2025, 09:24:24 PM »
Some of us like more than three
Crikey, there's a lot of work in that single part  :o  :praise2:
Offline redhouseluv
Re: Mount Trapezium
« Reply #64 on: April 15, 2025, 01:03:01 PM »
I was thinking the same, still got the steam passages, holes for both covers, exhaust port, exhaust flange, valve chest holes!
Made the steam pockets this morning
Offline redhouseluv
Re: Mount Trapezium
« Reply #65 on: April 15, 2025, 06:26:54 PM »
Drilliing steam passages is not for those of a nervous disposition!
Anyway, it's done, no mishaps I can detect; I now think the parallel to the bore steam passages is going to be the way forward for me, rather than how I just did them angled in. However, I guess the ports have to be deeper to align with them?
I got a chance to use a coaxial indicator in anger for the first time, that turned out to be a handy gadget
Re: Mount Trapezium
« Reply #66 on: April 15, 2025, 06:58:57 PM »
Yeah, depending on the  angle of the passages, you may need to deepen the ports to connect up. Run a drill or rod into each hole and mark the depth on the rod, then pull it out and lay the rod down the side of the cylinder. Same for the ports. That will tell you which, or both, need to be deeper and how much. Definitely  don't want to  drill too far!
Re: Mount Trapezium
« Reply #67 on: April 15, 2025, 07:42:14 PM »
Good work on the passages, glad you overcame your fears  :Lol:
Offline redhouseluv
Re: Mount Trapezium
« Reply #68 on: April 15, 2025, 08:39:25 PM »
Nearly messed up, but felt the resistance early on - I bought brand new drill bits especially for this exercise and they were as blunt as the backend of a bus! I ended up using the old one I had and it went through easily with a lot of stopping, clearing swarf and a drop of oil.
I can't understand how new drill bits can be so useless? What are the best drill bits, what should I look for, what material and spec, because the ones I bought from eBay are bin bound!
Re: Mount Trapezium
« Reply #69 on: April 15, 2025, 08:55:47 PM »
I like the Dormer A002 which are the standard jobber length but most of the time use the shorter stub length version which is the A022. These are split point so a lot of the time you can start them without spotting when using in the mill.
ARC did have them on special the other day, not sure how long it was for.
Re: Mount Trapezium
« Reply #70 on: April 15, 2025, 08:59:04 PM »
I've had that happen on a couple too, the outer corners of the tips of the flutes on a couple I bought were rounded.  Was part of a batch of replacements for ones with a lot of use and going dull, I didn't use them for a long time and it was way too late to return them.  :Mad: Learned to check new ones right away!  the last couple years I've been buying the cobalt steel ones, split point, from Aircraft Tool Supply. Very good prices, and they carry all the fractional, number, letter sizes. They also have multipacks of some sizes, I buy those for the tap drills on the sizes I use the most.
Offline redhouseluv
Re: Mount Trapezium
« Reply #71 on: April 15, 2025, 10:53:40 PM »
Great thanks I'll take a look, I don't like the thought of any drill bit bit snapping off in a piece of work let alone a new one; I'd rather buy the better quality product and de-risk!
Re: Mount Trapezium
« Reply #72 on: April 16, 2025, 12:44:43 AM »
I've had some of the better quality ones come through that way too - best to check them when purchased.
Offline redhouseluv
Re: Mount Trapezium
« Reply #73 on: April 17, 2025, 10:05:54 PM »
New Dormer drill bits arrrived today - I'm going to need them, lots of drilling still to do
More cylinder work today, broke through to the exhaust port and made and fitted the flange
Offline redhouseluv
Re: Mount Trapezium
« Reply #74 on: April 18, 2025, 05:02:13 PM »
I've been making holes......
more holes.....
some more holes.....
and even more holes.....
Finally the cylinder is finished and the guides and valve chest mounted ........I've ended up with some bizarre looking object which looks like a trophy someone has cobbled together with some random bits from their shed!  :ROFL:
