Author Topic: Mount Trapezium  (Read 75168 times)
Re: Mount Trapezium
« Reply #330 on: June 13, 2025, 06:54:12 am »
Thin disc in an angle grinder for the long cuts then stitch drill the ends and finish by milling.
Offline Charles Lamont
Re: Mount Trapezium
« Reply #331 on: June 13, 2025, 08:51:05 am »
I would have not have bothered with the chain drilling and gone straight in with a slot drill. Two or three trips all round to get to depth, leaving about 0.010" on the sides for a full-depth climb cut to finish. I would pull out and reposition for feedscrew backlash at the 'wrong' end of each cut as I have no DRO.
Online Sanjay F
Re: Mount Trapezium
« Reply #332 on: June 13, 2025, 03:11:29 pm »
Oh right - there are better options than the long route I took, good to know. I'll remember for that for future! In the meantime I've been attacking the woodwork and have again gone in with holes and mill, although given what has been discussed, a little OTT :D
The result is looking good though which is always a bonus .........right, finally time to continue assembling an engine!
Re: Mount Trapezium
« Reply #333 on: June 13, 2025, 04:49:06 pm »
Oooh, looking good!
Online Sanjay F
Re: Mount Trapezium
« Reply #334 on: June 13, 2025, 06:56:28 pm »
I decided to put off loctiting the crankshaft and crankpin to the web as it becomes very difficult to assemble/disassemble everything; I imagine I'm going to be doing this several times over the course of the next few days. So......I have drilled and tapped some holes for a pair of small grub screws as a temporary measure; will fix permanently at the end.
Now cutting lengths of 8BA threaded bar to make studs ........there are a lot of them and I'm glad I bought nuts which are 1 size smaller in OD (9BA) as there are some small spaces in which thery have to fit!
Online Sanjay F
Re: Mount Trapezium
« Reply #335 on: June 14, 2025, 04:35:55 pm »
The day started off with unspeakabkle acts of violence against the eccentric rod to get it bent into shape!
In order to get an even port opening I had to file the inside of the valve chest, round the corners of the slide valve, reduce the thickness of the valve rod gland and reduce the collar on the crosshead.
Here is the result: https://youtube.com/shorts/NIqWrTHLlNc
The piston is in it's home and making a 'pistony' noise with a liberal dose of oil
https://youtube.com/shorts/z93yhTZgn7Y?feature=share
Annoyingly, I've run out of 8BA threaded bar as the place I buy it from mistakenly sent 7BA so for now have ground to a bit of halt  :(
Re: Mount Trapezium
« Reply #336 on: June 14, 2025, 06:18:44 pm »
Now everything's fine.
There was little space in the upper part of the steam box.
Online Sanjay F
Re: Mount Trapezium
« Reply #337 on: June 15, 2025, 06:01:40 pm »
More assembly today, then disassembly  fettling, followed by more assembly and lot's of oil ...........getting there slowly, just waiting on some supplies  ::)
https://www.youtube.com/shorts/QbidyDCFCG0
Re: Mount Trapezium
« Reply #338 on: June 15, 2025, 06:35:30 pm »
Looks very elegant!
Michael   :ThumbsUp:
Online Sanjay F
Re: Mount Trapezium
« Reply #339 on: June 15, 2025, 07:58:45 pm »
I couldn't wait for supplies to arrive so blanked of the valve chest holes with gasket paper and look what happened! It's running on very little air  :cartwheel:
https://youtube.com/shorts/f_UCewxYDy0?feature=share
Re: Mount Trapezium
« Reply #340 on: June 15, 2025, 08:28:57 pm »
That's fantastic  :praise2: Well Done!!
Re: Mount Trapezium
« Reply #341 on: June 15, 2025, 10:25:37 pm »
Always good to see it run!  Congratulations!  :ThumbsUp: :popcorn:
Re: Mount Trapezium
« Reply #342 on: June 15, 2025, 10:36:52 pm »
Beautiful!  Very smooth runner, mesmerizing motion!
Re: Mount Trapezium
« Reply #343 on: June 16, 2025, 06:51:08 am »
Running well :)
Online Sanjay F
Re: Mount Trapezium
« Reply #344 on: June 16, 2025, 07:14:34 am »
Thanks everyone, I can’t stress enough how it was a team effort over the last few months. I’ve learnt a great deal for future projects and enjoyed it very much
I’ll be dismantling it and giving it a lick of paint and reassembling it properly over the next little while  :ThumbsUp:
« Last Edit: June 16, 2025, 02:54:42 pm by redhouseluv »
