Author Topic: Musgrave Non dead centre Engine assembly  (Read 9485 times)
Offline geoff5269
« on: March 15, 2025, 08:58:12 PM »
It's taken me about 6 months to build this Engine from plans by Julius, I have reduced it to 80% and it is made of Aluminium and Maple wood with Brass for the cylinders.
I was attracted by the unusual design and I hadn't used rotary valves before, the challenge is in the columns and the A frame.
<a href="https://www.youtube.com/watch?v=pDZFePQDzME" target="_blank">http://www.youtube.com/watch?v=pDZFePQDzME</a>
Geoff
« Last Edit: May 26, 2025, 11:40:20 AM by geoff5269 »
Online Sanjay F
Re: Musgrove Non dead centre Engine assembly
« Reply #1 on: March 15, 2025, 09:14:33 PM »
Incredible, very impressive and each component looks so well made and finished! So looking forward to the next episode......  ;D :popcorn:
« Reply #2 on: March 15, 2025, 09:33:35 PM »
I always liked the NDC engines!
Yours is beautiful!    Very tastefully done
« Reply #3 on: March 15, 2025, 10:13:08 PM »
Wonderful work on that engine!!  Have you tried running it yet?
Offline geoff5269
« Reply #4 on: April 03, 2025, 12:05:25 PM »
Here it is finished at last and I'm very pleased with it. I might make some changes later but I'll give it a rest for now.
Geoff
<a href="https://www.youtube.com/watch?v=LpkzE6XEKGg" target="_blank">http://www.youtube.com/watch?v=LpkzE6XEKGg</a>
« Reply #5 on: April 03, 2025, 04:57:04 PM »
Very fascinating motion!   :ThumbsUp: :popcorn:
It'll be interesting to see how much difference changing that middle piece will have on the engine.  It seems like it will improve it significantly to get those little links more in line with the cylinder rod travel.
Online Sanjay F
« Reply #6 on: April 03, 2025, 08:43:18 PM »
That's a lovely looking engine, with a hypnotic movement - well done, grand job! :)
Offline geoff5269
« Reply #7 on: May 19, 2025, 04:44:04 PM »
Here is the Musgrove with some changes I hope make it run better, I got a heavier fly wheel as the first one was only 260grams and seemed a bit light so I bought one made of Zermak which is 700 grams and was easy to machine. Timing is tricky with this engine so I found fitting a tube to the exhaust and holding it to your ear lets you hear the valve opening.
Geoff
<a href="https://www.youtube.com/watch?v=5kgi8yf3xLU" target="_blank">http://www.youtube.com/watch?v=5kgi8yf3xLU</a>
« Reply #8 on: May 19, 2025, 05:18:47 PM »
Great work!
« Reply #9 on: May 19, 2025, 05:53:09 PM »
Very cool!  :ThumbsUp: :popcorn:
The wider triangle middle piece does change the motion quite a bit, doesn't it?  Interestingly, the little black connector (between the triangle and the piston rod) on the right side wiggles around a lot more than the one on the left side.  And I think the larger flywheel really makes a big difference too.
Well done!
Offline flopearedmule
Re: Musgrave Non dead centre Engine assembly
« Reply #10 on: July 07, 2025, 12:48:10 AM »
Great job Geoff!  It looks really good!
How did you attach your pieces for the head?  Did you glue them?
It sure made a big difference making the cross head a bit wider.
Offline geoff5269
« Reply #11 on: July 17, 2025, 11:25:23 AM »
There are many pieces to make the Head and they are mostly glued and some screws thru the bottom plate where they don't show.
Geoff
