Author Topic: HV-6 rotary table - dividing plates  (Read 5823 times)
Online Sanjay F
« on: March 05, 2025, 09:19:05 pm »
I went to fix my new dividing plates to my rotary table which looked relatively simple, remove handle and fix plate using 3 hex bolts and to my surprise and disappointment there are no holes! Look at last image from a video - that's what I was hoping to see
I took the locking ring off as well, but there's no way of holding these plates - has anyone comes across this before or are there some other types of dividing plates? OR am I being a bit dumb? Not too keen to be drilling holes into the inner locking ring but...........
I'm sure where I bought them from will allow me to return them as they are unopened, but that doesn't resolve the problem!
« Last Edit: March 05, 2025, 09:22:10 pm by redhouseluv »
Offline uuu
Re: HV-6 rotary table - dividing plates
« Reply #1 on: March 05, 2025, 09:33:35 pm »
In order to get the holes correctly spaced you'll need to mount the relevant component onto some kind of flat device that can be rotated with precision.
Wilf
Online Sanjay F
« Reply #2 on: March 05, 2025, 11:04:41 pm »
If had to drill it I have a smaller rotary table I could use to rotate it, however, given the issue so far I would need to check the plate centre and spindle are the correct diameter otherwise its a non-starter.
Google tells me:
PCD: 32mm
Inside diameter: 21mm
Outside diameter: 100mm
Thickness: 7mm
Hmmm......
« Reply #3 on: March 06, 2025, 06:57:04 am »
You could spot them through, mine has quite generous clearance size holes and the screws are not exactly high quality.
Online Sanjay F
« Reply #4 on: March 06, 2025, 09:22:48 am »
Thanks, I was thinking that, let me check the spigot on the table is the correct size for the plates.
Online Sanjay F
« Reply #5 on: March 06, 2025, 11:15:58 am »
Hooray, nice quick job and worked well, thanks all - now back to building engines!  :D
