Author Topic: Hall Sensors dying on Holt 75  (Read 14999 times)
Offline michelko
« on: March 02, 2025, 12:26:34 PM »
Hi Guys,
since i got my Holt running it worked real nice with that cheap chinese CDI Ignition.
But since a couple of days the hall sensor going mad.
I changed 7 or 8 times but the engine will only run a couple of seconds to a couple of minutes fine and suddenly stops.
And another hall sensor is fried. I changed the holder of the Hall sensor from bras to delrin, helped not. Changed to another CDI, same symptoms.
Has anyone a good idea whre to look?
I am a little frustrated now.
Regards Michael
Offline michelko
Re: Hall Sensors dying on Holt 75
« Reply #1 on: March 02, 2025, 12:29:34 PM »
https://www.stirlingkit.com/products/ignition-starter-kit-for-horizontal-combustion-engine-hit-miss-gas-model
this is the first ignition i used with succes for some time.
https://mbi-design.de/wp/produkt/cdi-zuendung-a-01/
that is the second one i testet with the same results.
Offline michelko
« Reply #2 on: March 02, 2025, 12:31:50 PM »
The Sensor is an Infineon TL 4905l
« Reply #3 on: March 02, 2025, 12:36:12 PM »
Have you measured the voltage coming out of the ignition going to the hall sensor?
« Reply #4 on: March 02, 2025, 01:17:06 PM »
In all my years of using Hall sensors I have only had two burn out, that is until my flathead engine. I must have gone through five with it. I ultimately traced it to my Hall lead to wire connection.  It was too close to the metal holder and one day I could see an arc jumping to ground. Make sure that you have a good path back to the negative battery connection and that all ground connections are good.
Offline michelko
« Reply #5 on: March 02, 2025, 01:36:06 PM »
Hi,
here are some pics of the setup.
The ignition only has two connections to the enngine. The red HT lead and the black ground. both were screwed to the engine.
The battery is an 2S Lipo so around 8V.
al the conections to the sensor were covered with shrink tube and the sensor itselv also.
That setup worked for months but suddenly started to fry the sensors.
« Reply #6 on: March 02, 2025, 01:48:19 PM »
The battery is used in the CDI to generate different voltages, one of which is the HV for the plug so the battery voltage is no indication of the voltage going to or across the sensor.
The guys have been describing a common problem: If the ground is not earthed to the engine or there is resistance on the return then the Hall sensor may be experiencing the HV as feedback and hence going "Pop".
Time to get your resistance meter out and check the earth is a good dead short all the way to the sensor. Then measure the feed and return from the sensor with the volt function. These devices are pretty good they can normally go over 30V DC but if the earth isn't there or is intermittent the voltage will float much higher.
The fact that you have tried two CDI's tells me it is something about the mounting on the engine.... its all pointing towards the earthing  ;)
Offline michelko
« Reply #7 on: March 02, 2025, 01:57:58 PM »
o.k.
7.6V at the red and black lines to the sensor
0.8 Ohm between the black line of the sensor and the black line to the case also between the battery ground.
I agrre to your earth suspect, but canīt find the cause.
« Reply #8 on: March 02, 2025, 02:37:32 PM »
0.8 Ohms is a bit high, allow for the engine to warm up its likely to move up or down but importantly it should be a dead short. The quick and dirty way to check if it is /solve the earth problem is to run an additional earth wire up and put it under the screw that mounts the sensor to the engine.
I suspect the other 0.4V from the battery is the float caused by the 0.8 ohms resistance. Have you buzzed out the wire going from the CDI to the sensor? Was it the same one used for the two CDIs?
« Last Edit: March 02, 2025, 02:41:41 PM by Jo »
Online Jasonb
« Reply #9 on: March 02, 2025, 03:39:46 PM »
Is that connector right. looks like red and white are crossed
« Reply #10 on: March 02, 2025, 04:23:05 PM »
The TLE4905 has reverse polarity protection.
Online Jasonb
« Reply #11 on: March 02, 2025, 07:16:24 PM »
None of my CDIs need a connection from block to the battery negative. My battery just has a futaba conector and that is how I connect to the CDIs supply.
The CDI ground is connected to the block like the bigger black wire in the photo and the plug lead to the plug.
« Last Edit: March 02, 2025, 07:21:01 PM by Jasonb »
Online Jasonb
« Reply #12 on: March 03, 2025, 07:48:13 AM »
The above was a reply to a post saying that the CDI needed a wire from engine frame to battery -ve which seems to have now been removed just incase anyone was wondering what it was about.
The CDI shown here has exactly the same wires as the popular S/S one from the States and the Minimag from the UK so no need for any additional wires. That has worked ok for me over 18 years since I first bought a S/S one.
2 wires to battery
3 wires to Hall Sensor ( less if just uning contats)
1 wire to spark plug
1 Wire ground to engine frame
Online Jasonb
« Reply #13 on: March 03, 2025, 07:54:50 AM »
But the wires that look to be crossed in the connector are not the +Ve and -Ne (ground) as the central negative or ground is black and right in the connector. so signal and positive look to be crossed
« Last Edit: March 03, 2025, 08:01:43 AM by Jasonb »
« Reply #14 on: March 03, 2025, 08:27:56 AM »
Reverse polarity protection means if the voltage is connected to the wrong pin the device won't instantly die and will still work if you realise and connect it correctly.
The initial condition was the engine was running happily from the connected CDI: This tells us the wiring was correct. Something has changed which has caused the device to blow. The logic is the likely thing to change is either wires have broken/come loose or in combination the warming of the engine is moving the wires causing a poor connection.
