Author Topic: Steam powered water pump plans  (Read 2257 times)
Offline kelltech
  • Jr. member
« on: January 22, 2025, 12:42:54 AM »
Hello everyone. I am new to this forum but not the hobby. I am retiring in March and will have more time to play. The reason for the post is that several years ago of a double deck 2 cylinder double acting steam engine on the upper deck connected by the crank to 2 double acting water pumps on the lower deck. It had hand rails all around both levels and a feed pump as well. Problem is I cant find the plans anymore. Would anyone know where I can find them, I have been wanting to do this for some years.
Any help would be greatly appreciated
Thanks KellTech
Re: Steam powered water pump plans
« Reply #1 on: January 22, 2025, 01:55:41 AM »
A few years ago I  did a three cylinder water pump, could it be that one? It was of the Holley pump from the Buffalo city pump station.
https://www.modelenginemaker.com/index.php/topic,10707.0.html
Offline TerryWerm
« Reply #2 on: January 23, 2025, 03:27:42 AM »
That sounds like one of Elmer Verburg's engines. I have included an attached image of Elmer's #17 Pumper. It does not have a dedicated feed pump that I am aware of, only the pumps driven by the engine. It has a bore and stroke of 5/8" each, and carries a 3" diameter flywheel. Overall height of the engine is about seven inches.
« Last Edit: January 23, 2025, 03:33:12 AM by TerryWerm »
Terry
Making chips when I can!
