Author Topic: The Bolton -Bertinat -Bailey Triple expansion engine  (Read 101059 times)
Re: The Bolton -Bertinat -Bailey Triple expansion engine
« Reply #120 on: August 07, 2025, 01:47:24 am »
to position the cranks correctly on the shaft I have made 3 new top caps with 7/32 reamed hols to line up with the bottom covers. the cranks will then be aligned correctly with the piston rods...
Willy
« Reply #121 on: August 07, 2025, 01:55:57 am »
Coming along great!   :popcorn: :popcorn:
« Reply #122 on: August 08, 2025, 10:19:37 pm »
thanks"C" and quite a few new things to learn about and do !! with this model....
Willy
Offline Sanjay F
« Reply #123 on: August 09, 2025, 07:00:32 pm »
Willy
That's a great idea, saves a potential issue down the line; it's really coming along very nicely :ThumbsUp:
« Reply #124 on: August 11, 2025, 04:36:47 pm »
Willy
Thanks and yes I do try and think ahead  :ThumbsUp: :ThumbsUp:
Willy
« Reply #125 on: August 15, 2025, 03:08:23 am »
I have continued with the crankshaft and have made the crank pairs and will position them on the crankshaft using the extended cylinder rods  The curves on the cranks are hand filled fit in the base casting.. The middle crank is attached with Locktite and drilled rods. the outer cranks are portion and I made positioning blocks to keep them in the correct place. the cranks are positioned at 120 degrees and I am thinking of using a three jaw chuck for this purpose........
Willy
« Reply #126 on: August 18, 2025, 03:51:25 am »
I have assembled the crank shaft using the chuck and numerous clamps and Loctite ..and will wait 24 hours for a good bond ...before drilling and pining................
Willy
« Reply #127 on: August 18, 2025, 03:55:46 am »
Nice!  Looks like a machinists Christmas  tree!
« Reply #128 on: August 18, 2025, 07:16:54 am »
Blimey, that tobacco tin took me right back...
<a href="https://www.youtube.com/watch?v=uVTFDhue6pQ" target="_blank">http://www.youtube.com/watch?v=uVTFDhue6pQ</a>
Sorry for veering so far off topic!
Online Roger B
« Reply #129 on: August 18, 2025, 08:02:17 am »
That's a good way to set out the crankshaft  :praise2:  :praise2:  :wine1:
« Reply #130 on: August 18, 2025, 03:26:43 pm »
Thanks , and Xmas  has come a bit early ??!!! :whoohoo: :ThumbsUp:
Willy
« Reply #131 on: August 18, 2025, 03:30:39 pm »
Thanks ..and I was a bit hesitant to do this , but it seems to have worked out ok
Willy
« Reply #132 on: August 19, 2025, 03:04:30 am »
The crankshaft is now glued together and been offered up to the base with the cylinder block in position. the positioning rods have been lowered and they line up with the cranks. As was expected the base casting is not cast with the main bearing parts in the correct places. The left hand ones are too close to the centre ones and vice versa with the right hand ones.??!!  this is why previous builders of this engine have hade to scrap theirs and remake a new base as wasexpirienced by  Simply Loco builder  John Barret in 2022!  I will have to reposition the main bearings to fit the finished crankshaft. The photos can show the misalignment ....
Willy
« Last Edit: August 19, 2025, 03:16:23 am by steam guy willy »
« Reply #133 on: August 23, 2025, 02:34:02 am »
I have made a jig to file the base standards in the correct places to take the main bearings using a small square to get them accurately in place...It is aluminium so is quite a quick job.
« Reply #134 on: August 23, 2025, 02:40:37 am »
Good save on the base!   :popcorn:
