Hi. I hope I'm not missing the possibly obvious but.......
I've almost finished machining the cylinder/water hopper casting for a Redwing and it's dawned on me that there are no dimensions given regarding the clearance between the piston at TDC and the cylinder head. The only dimensions I can see is the length of the cylinder, height of piston, conrod length and crank throw. The only guidance given is to remove appx .060 from the head end of the cylinder to achieve a cylinder length of 4 7/16". This is easier said than done considering the rear end of my cylinder casting is extremely 'uneven' to say the least, which gives me no reliable place from which to take a measurement. Does anyone have any advice on how to achieve the correct squish clearance??
Thanks in advance, Grubscrew.
