Author Topic: The Webster Chicago  (Read 21124 times)
Offline maury
    • Lone Star Engine Works
The Webster Chicago
« on: December 27, 2024, 06:41:47 pm »
After about a year and a half working on the Fairbanks-Morse R
3 cylinder, I needed a break. Nearly done, I need to set up for powder coating
and finish a few minor details before final assembly.
 I have a freind who has access to  a partially disassembled Chicage Webester,
 and he feels the strong urge to have a model of it. I've gotten the bug too, so
we decided to get started measuring it. A month or two back. Information
trickled in and there were a lot of questions and more measuring and pictures.
So, I've spent the past few weeks with Solidworks cranking out a design.
Currently the modeling of most of the parts is complete, and everything  seem
 to fit properly in the elevation, though I'm sure there will be engineering
changes  during the building phase.
This will be my first hot tube design, so a few new challenges.
I will be making the patterns for castings and casting some of the parts for the
prototype in aluminum. My friend has assess to an iron foundry, so he will
supply the iron castings. I just got a new Bambu Labs A1 printer, and can't wait
to start making patterns.
Maury
Re: The Webster Chicago
« Reply #1 on: December 27, 2024, 07:00:14 pm »
I'll look forward to this one coming together, what sort of size have you gone for?
Offline Alyn Foundry
« Reply #2 on: December 27, 2024, 07:28:12 pm »
I have a ‘ bit of a thing ‘ for inverted vertical engines…. 😉
I too will be following the progress. Regarding hot tube ignition, yes it does scale but within certain limits.
We also use a Bamboo labs 3D printer, very pleased with its performance. Here’s a sample of recently produced patterns.
 :cheers:  Graham.
Offline maury
« Reply #3 on: January 04, 2025, 04:47:10 pm »
Well, Im back after my Computer gave me a big scare. It would not boot, gave a CPU fan error. After checking it out (???) I ended up taking it in to a repair hack shop to get it repaired. Fortunately, it was only the fan that was broken. It's my CAD computer, and everything I've done since 2013 is on there.
So, I've been printing some patterns which were exported before the fan issue. These are the parts I need in iron for building the prototype, and have been sent to my friend for casting in iron.
Most are strait forward except the Exhaust valve cage. That part has really unusual geometry, and I have no ldea how it was initially manufactured. After studying it some, I decides to pattern the bottom of the part split in cope and drag. The top of the part has its geometry in an external core. Thus is the first part I've made like this, We'll see how it goes.
« Reply #4 on: January 04, 2025, 05:39:59 pm »
Hopefully all backed up onto other drives too? Still a pain to restore on a new machine if needed, but it least it isnt lost that way.
Offline maury
« Reply #5 on: January 04, 2025, 06:09:01 pm »
Thanks to all who have tuned in.
I won't loose my data, its the applications I'm worried about. My Solidworks License is 2013 and my Bob Cam 4 axis software is also no longer "supported". I won't be buying new versions if I loose my computer. I'll still have my lathe and bridgeport though.
Offline maury
« Reply #6 on: January 10, 2025, 09:10:25 pm »
Still too cold to work in the shop here so I'm printing more patterns and working on shop drawings. As soon as we get a reasonably warm clear day Ill be pouring castings of these patterns. With any luck, the ones I sent to the iron foundry will be back next month. Still working on the water jacket pattern, and core box. It has some really interesting geometry. Can't wait to start cutting metal.
Offline maury
« Reply #7 on: January 14, 2025, 07:50:51 pm »
Well the weather has cooperated, so a good opportunity for foundry work.
I always have a bit of anxiety about trying out a new core box, but this one worked well.
I cored out the exhaust passage and combustion chamber in the head. The rest of the parts are
for the intake, bearing caps and the latchout. I was concerned about the yoke, as it is only 3/16 thick
and wide in sections. The part filled well, can't wait to get it on the Bridgeport.
There will be another batch of castings before I can get into cutting metal though, and more pattern
making.
« Reply #8 on: January 15, 2025, 06:24:09 am »
I'm absolutely no expert on castings - but they look good  :ThumbsUp:
Enjoy your time machining them  :cheers:
Per            :popcorn:
Offline maury
« Reply #9 on: January 17, 2025, 09:48:31 pm »
Thanks for the compliment on the castings
I still have more patterns to make, but I wanted to start cutting metal. not having all the castings, I decided to start with the valve train. I only need 1 casting for that.
Offline maury
« Reply #10 on: January 31, 2025, 07:09:58 pm »
Continuing on in the shop I decided to check out the head casting. For this I needed to break out my rotary table
which I haven't used for many moons. Drilling the water passages is a bit tricky as the holes need to align across
different setups, so special attention is given to precise alignment in the setups.
« Reply #11 on: January 31, 2025, 09:01:18 pm »
That is looking like good progress Maury!
I didn't realize that you were working on a Fairbanks R, or I didn't remember. Are these PMD castings or your own?
I noticed that on one of the tables at the Cabin fever show video there were some R castings that apparently someone is working on making.
Offline maury
« Reply #12 on: February 01, 2025, 02:03:12 pm »
Dave, thanks for tuning in. Yes, I'm building a Fairbanks R 3 cylinder. About 8 to 10 years ago I bought the prints for this engine from Bob. I've always wanted to build this engine, and when PMD imploded I just set them aside- plenty of other projects. I made patterns and aluminum castings in my foundry, and after about a year I now have an almost completed engine. Next step is to powder coat it before final assembly.
The patterns went to a friend who is interested in producing the kit. The drawings have been redone in Solidworks, are completed and checked.
When I get my iron set of castings, I might do a build log
Offline maury
« Reply #13 on: February 26, 2025, 03:06:16 pm »
Time for an update. I have machined the intake section as much as I can at this point. Still waiting for the iron casting for the exhaust and hot tube which also connects this assembly to the engine.
Offline maury
« Reply #14 on: March 01, 2025, 05:37:57 pm »
I had some more shop time this week, working on some of the general assembly parts while waiting for the iron castings.
The needle valve is for controlling the gas flow for the hot tube. Since I have little experience with hot tube ignition, I may dummy up a hot tube system to sanity check my design before cutting on the casting.
The latch out assembly is complete now, and is waiting for the flywheels assembled with the governor balls.
I have word that the iron castings will start trickling in soon.
