Could you drill and tap a pair of mounting holes in your face plate?Nice start, I will be following along.Dave
At 16mm thick I would drill and counterbore for a couple of say large say M10 cap heads or whatever size your mill clamps are then you can use the tee nuts from that which won't rotate in the faceplate slots as you tighten them. Which will mean you can skim right across.
I drilled and reamed a 6mm hole in the centre of the base plate which allows me to move from the lathe to the RT without losing the centre. The lathe operations are centred with a piece of 6mm ground stock held in an MT collet in the headstock.
when you mount that bar on the face plate to machine before clamping se that it is sitting flat then cut the same off each side before clamping see that it is sitting flat pack with shim if it is not.dont leave long between machining both sides.after machining leave for as long as you can then check if it is still flat often steel or aluminium is worse depending how it is made once you cut the surface it will move you can use the lathe or milling machine to get it flat first.
