Author Topic: Sirius: Alco "Firefly" version  (Read 23790 times)
Offline Sanjay F
Re: Sirius: Alco "Firefly" version
« Reply #15 on: December 10, 2024, 01:37:30 PM »
Big thank you to Ron from the Alco firefly website for creating the template for the lagging - it worked out well and making a 0.020" fastening disc to hold it together was interesting
I couldn't look at the dayglo green any longer and went to town with the paint stripper - looks much better already
Having removed the baseplate and oiled top and bottom sides, everything seems to rotate very smoothly - fingers crossed it will run once I get a chance to make the inlet
<a href="https://www.youtube.com/watch?v=rxZoM0VO9vg" target="_blank">http://www.youtube.com/watch?v=rxZoM0VO9vg</a>
Offline Sanjay F
« Reply #16 on: December 12, 2024, 12:14:55 AM »
Award for dumb question.......
My early Christmas present arrived today, the Sievert gas torch, nozzle and regulator, I presume its just a standard propane gas bottle I need, like one for a gas BBQ?
The 1/4" BSP olive and nipple also arrived today (fits like a glove, TY); is anyone else experiencing Royal Mail stock piling packages and then delivering them all at once?
« Reply #17 on: December 12, 2024, 12:32:35 AM »
Merry Christmas!   Yup, standard  propane grill tank. Here in the  US its a 20 pound tank. Be sure to leak test the connections with soapy water. Look close at the threads, usually  left hand on these!
Offline Sanjay F
« Reply #18 on: December 12, 2024, 12:35:56 AM »
Thanks for the quick reply, I'll be going to get one of those 1st thing tomorrow morning and I'll be sure to test it! :ThumbsUp:
« Reply #19 on: December 12, 2024, 12:42:34 AM »
Oh, and do you have one of those sparker thingies to light it? Do not use a match!   :zap:   When lighting, it can take a few seconds for the  propane to fill the hose, light it with the valve cracked open, not wide open.
Offline Sanjay F
« Reply #20 on: December 12, 2024, 01:03:30 AM »
errrr.....no, I haven't, I'm glad you mentioned it, as I'd rather keep my fingers ;D
« Reply #21 on: December 12, 2024, 07:14:38 AM »
No you don't want one like your BBQ as that will be Butane (blue bottle) or garden/patio gas (green bottle)
You need propane in the orange bottle as the others have different threads/bayonet fittings. It's a left hand thread on the propane. Probably have to be a 7Kg as the smaller ones have been phased out.
I use a cheap cigarette lighter.
Offline uuu
« Reply #22 on: December 12, 2024, 08:19:49 AM »
I've tried various devices for lighting.  I wouldn't trust myself with a cigarette lighter (My friend John is used to having no hair on his fingers).  I'm not fond of the kitchen stove lighters that emit a flame - they just get blown out by the rush of gas  (Crueby's noted you don't want too much gas at light-up).   The sort that just spark are very good.
Or a welders sparker - which has a little cup to catch a pocket of gas:
Wilf
PS Sievert put a helpful little nick on the corners of all the hexagons that are left handed.  So you'll see the nozzle-end ones are right hand and the hose and regulator are lefties.  It's a handy reminder.
« Last Edit: December 12, 2024, 08:39:10 AM by uuu »
Offline Sanjay F
« Reply #23 on: December 12, 2024, 09:37:43 AM »
Thanks for the replies - I was just about to order a bottle for pick-up, I have found the right type not too far away.
« Reply #24 on: December 12, 2024, 12:02:46 PM »
Ah, must be a regional difference, here in US we dont have as many variations,  the BBQ tanks for propane are what fit. Good catch!
« Reply #25 on: December 12, 2024, 12:30:07 PM »
The Garden or "patio gas" is propane but I've only ever seen then with a clip on type fitting and all the regulators for that are low pressure so you won't get the heat out of the gun which would take us back to square 1
Offline Sanjay F
« Reply #26 on: December 12, 2024, 01:09:16 PM »
All sorted - I now have an orange bottle, with screw connector which I checked has the same thread as the regulator. I'll hook it all up and have a new attempt at soldering ........ if you don't hear from me, things haven't gone well   :ROFL:
Offline AVTUR
« Reply #27 on: December 12, 2024, 01:42:06 PM »
I use a Sievert 3488 handle which includes a low flow gas setting. Once it is set up with just the slightest of pilot flow and no main flow it can be safely lit with a match.
Two words of warning: Alway use spanners to do up the unions, particularly on the handle. A hose failure valve should be used downstream of the regualtor. Putting the torch flame through the gas supply line would be very interesting.
Propane torches can give out a lot of heat. I do all my silver soldering outside. Too many things can catch fire in a workshop. Think about what you are wearing. Oily cotton overalls are not a good idea. Again I have a welder's glove on my non-dominant hand. Also, Propane bottles should stored outside.
Given the above, silver soldering is a very satisfying occupation. You may meet all sorts of interesting problems. Have fun and I hope you progress on to heat treatment.
AVTUR
Offline Sanjay F
« Reply #28 on: December 12, 2024, 05:46:02 PM »
Thanks for all the valuable advice, I'll check all the connectors and do the soap trick to ensure a good seal. I have sparker arriving tomorrow so it will probably be the weekend before I give it a try.
I'm looking forward to it, I enjoy learning new practical skills, especially as I sit in front of a computer all day wishing I was in the workshop  ;)
Offline Sanjay F
« Reply #29 on: December 12, 2024, 11:54:00 PM »
I'm finding all sorts of interesting things on this engine
- The conrods halves have matching numbers stamped on them
- Like a car the engine and 'chassis' have serial numbers which also match
I found an appropriately sized pressure gauge to replace the missing one, but was looking very shinny, so aged it with some bicarbonate of soda and tea  :)
« Last Edit: December 13, 2024, 01:02:10 AM by redhouseluv »
