Author Topic: Mery Engine fuel system question  (Read 11745 times)
Offline JBM3M
« on: November 18, 2024, 11:39:32 pm »
 :old:
This is the second Mery Engine I have built from Martin Models castings.  The first one would run for 30 seconds tops and quit.  Sold it out of frustration.  But I think now after a couple years of thought; how does it get air mixed with the fuel?  I was not giving any air and thus the thing would run after a spell of not running and then quit, flooded I assume.
Well I have reached the same point.  Built the Jerry Howell demand valve which is a type of demand that is suction from the engine.  This is a very low compression engine BTW.  So if one introduces an air jet or ? for air it will kill the suction on the demand for the propane.  I at a total loss how to resolve this, but I see photos of someone elses Mery and it appears it has an air intake after the demand valve.
Still have to setup the ignition timing so am a bit away from completing the fuel system.  The demand valve is ready to go, but have to complete the fuel lines to the explosion chambers, so I think this is the time to address this issue.  Hopefully a successful Mery owner will have my answer?   :NotWorthy:
Re: Mery Engine fuel system question
« Reply #1 on: November 19, 2024, 01:09:27 am »
You need to meter the air as well as the propane, the mix is very critical, so touchy to adjust and get correct. I will get a video and photos of my friends engine sometime this week, his engines runs great!
He has built separate fuel and air adjustments into the mixer. He also uses a demand valve which is most likely very similar to Jerry's design.
Offline JBM3M
« Reply #2 on: November 19, 2024, 01:35:28 pm »
Is your friend local to Boise?  I live in Nampa.
Offline Chipmaster
« Reply #3 on: November 20, 2024, 12:01:01 pm »
Hi JBM3M,
I began building a Mery Explosive a couple of months ago so I'm keen to see how your gas/air intake turns out.
Andy
« Last Edit: November 20, 2024, 02:56:27 pm by Chipmaster »
Offline Alyn Foundry
« Reply #4 on: November 20, 2024, 02:30:34 pm »
No IC engine runs solely on fuel. We need a percentage of air mixed accurately for each cylinder charge. petrol/gasoline is pretty flexible but Propane and Butane are quite particular about the ratios. The Mery is normally aspirated and if set to run at a particular speed should not need any form of demand type gas valve. However from a safety aspect that type of control valve is useful should the engine stop for any reason.
For Propane fuelled systems a high quality adjustable regulator is recommended. And for fine control a secondary needle type of valve placed as near to the intake as possible will help immensely.
My own technique for setting up gas, gas engines is to use the burning flame method. By holding a taper or flame near the exhaust pipe and watching the exhaust burn. If you get bursts of Yellow then the mixture is way too rich. You’re looking for a nice, Bunsen Blue ! 😉
 :cheers:  Graham.
Offline JBM3M
« Reply #5 on: November 22, 2024, 02:25:02 pm »
Graham, if you have link or suggestions for a regulator such as you mentioned?
« Reply #6 on: November 22, 2024, 03:04:29 pm »
Try this one.
https://www.gasproducts.co.uk/cavagna-high-pressure-adjustable-propane-regulator-0-5-to-4-bar.html
Alternatively depending upon your location, any precision pressure variable regulator should work. It should be noted that bottled gas pressures vary depending upon both temperature and barometric pressure….😉
 :cheers:  Graham.
Offline Chipmaster
« Reply #7 on: November 22, 2024, 05:25:55 pm »
I have satisfactory results running my Alyn Foundry engines using Cadac regulators on Coleman C500 cartridges their output is 30mbar, about 0.4psi.
Andy
« Reply #8 on: November 22, 2024, 05:30:14 pm »
Yup, we are both in Boise.
I just uploaded a video of his engine that I took yesterday.
<a href="https://www.youtube.com/watch?v=hW52BFZACbo" target="_blank">http://www.youtube.com/watch?v=hW52BFZACbo</a>
Offline Chipmaster
« Reply #9 on: November 22, 2024, 05:44:43 pm »
Magnificent, such a steady and smooth running engine.
Thanks for uploading the video.
Andy
« Reply #10 on: November 22, 2024, 05:50:57 pm »
The counter weights on the crankshaft make a huge difference.
Thanks,
Offline JBM3M
« Reply #11 on: November 23, 2024, 12:51:08 pm »
Thanks,
I didn't oversize this time, so we shall see.  Would dearly love to speak/meet with this gentleman.  Would like to see his fuel setup, not quite visible enough in the video.  Damn she runs smooth.
Offline JBM3M
« Reply #12 on: November 26, 2024, 01:44:29 pm »
I could add counter weights to the crankshaft, machine up a couple out of lead if need be.  Got a ways to go to worry about that.
Offline JBM3M
« Reply #13 on: December 27, 2024, 04:23:00 pm »
So I have been all over the internet trying to get a basic jet size for the propane fuel system and at what steady pressure?  I am getting a couple pops and that is it.  Firing either cylinder at TDC.  Do not have a purge valve, just single exhaust each cylinder.  Compression is noticed, unknown value.  I do seem to get a purge out on the intake side of things in addition to the exhaust purge out.  At this point guessing on "jet" size. Thanks
« Reply #14 on: December 27, 2024, 06:12:25 pm »
Are you using a demand regulator so the engine only gets fuel when called for? If not and you are just trying to flow it in it will be super easy to flood the engine.
I can supply plans for a regulator that works very good.
