Author Topic: Model Engineer Beam Engine - Reeves Kit  (Read 21871 times)
Offline Kim
Re: Model Engineer Beam Engine - Reeves Kit
« Reply #30 on: April 19, 2025, 11:37:54 PM »
Very nice top hat!  :ThumbsUp: :popcorn:
And I love your monitor!  That's a great use for a repurposed TV!  Nicely done!
« Reply #31 on: April 20, 2025, 09:29:22 AM »
Hello Stuart,
I'm glad you're continuing to work on the engine. The new cylinder head cover is a good idea.
When I place the cylinder head under the beam, it's also slightly off-center from the rounded space on the aluminum base.
Offline propforward
  • MN, USA
    • Stuart's Shednanigans
« Reply #32 on: April 20, 2025, 03:20:07 PM »
Thanks Michael - a lot going on in life unfortunately, too many distractions from what I want to do but such is the way of things. Gradually getting those distractions out of the way.
Those off center features don't affect anything other than slight appearance - but I'm glad I did the clean up.
So, the fun bit is getting the angled face on it at the right height and clocked correctly to the bolt pattern. Not all that hard - and as mentioned, if one were to eyeball it and mark the height front and back, paint some blue on, scribe a line etc it would all work out.
But I decided to make a holding fixture out of a piece of scraptonium, including a mating dowel pin hole at the center, the bolt pattern in the head / ring and another dowel pin for a tooling ball. The tooling ball acts as an easy to establish reference, the holding fixture is then angled making use of a sine bar.
I’m changing all the BA threads over to UNC or UNF threads which are easier to deal with stateside. There are close enough sizes. Not equivalent – they won’t play together – just similar physical sizes. I tabulated the whole arrangement. I was surprised I couldn’t find anything already done, figured that must surely have been done and shared before.
Anyway – the fixture block was all squared up and the center hole drilled and reamed, and bolt pattern added. Here it is tapped with my home-made small tap holder.
The idea of using a tooling ball to establish location actually came to me after making the fixture to that point. My original plan had been to use a dowel pin, but it would have been difficult to keep perpendicular to the vise jaws. The tooling ball is easy – here is a reamed hole being added. I’m using a kool mist mainly to blow chips away so nothing gets jammed in the reamer to make the hole go oversize.
Tooling ball fitted – a nice close, slip fit.
So, this drawing helps to explain the point of the ball.
The drawing has the dimension from the top of the ball to the finished wedge surface – so now you can see that it is possible to set up the fixture in a vise on a sine plate, touch off an end mill on top of the ball (by way of a feeler gauge so as to not damage either end mill or ball), and then bring the tool down (actually the mill knee up) until dimension from top of the ball to finished surface is reached. Now the wedge is very accurately created.
Although I have CAD and it’s easy to measure the dimension needed, I like to do the trigonometry. I’ll show the triangles here and how that works for the fun of it. I feel like making the effort to do the maths increases overall understanding of geometry – and it’s just a bit of trigonometry. I drew this up to show the relevant calculations and geometry.
Hopefully that’s self-explanatory. For anyone interested in the details I will go through the calcs on the video I am putting together for this, but basically the numerical dimensions are the known values – dimensions desired on the final part etc, and the dimensions in letters are what have to be calculated to get the vertical dimension that references from the top of the tooling ball to the finished angled face, when the part is set up in the milling machine.
So OK – with that known here is the set up – using a sine bar to get the angle as accurate as possible. Yes – more trigonometry! I expect you all know this. The center distance of the pins on the sine bar are 5” apart, so to set the angle calculate the height of a stack of gauge blocks to put under the rear pin. Sin (5.572) X 5.0” is the calculation.
Enough waffle – pitchers here.
So then after touching the face of the end mill off on the top of the tooling ball (using a feeler gauge) it’s just a matter of raising the knee gradually and carving away the material.
Simple enough and quite satisfying.
2 parts down, lots more to go.
Stuart - "He Meant Well"
« Reply #33 on: April 20, 2025, 03:24:29 PM »
Great attention to detail!  I assume the purpose of that sloped end is to let condensate in the cylinder run down to a drain valve?
Offline propforward
  • MN, USA
« Reply #34 on: April 20, 2025, 03:30:29 PM »
I think that is correct Chris - nothing is specifically included but the plans point to that location for a drain cock. If this were to only be run on air I guess that wouldn't matter too much, but running on steam is more fun! Hope to do that some day.
Offline propforward
  • MN, USA
« Reply #35 on: April 28, 2025, 02:32:14 PM »
I made a video about this component, so it's here in case anyone is interested, complete with chapters so you can skip over things if you want.
It's a half hour and frankly is mostly discussion about how to do the geometry around the tooling ball and the angled surface, but I feel like there tends not to be an appreciation of that kind of thing in a lot of home shops. Well, anyway there it is.
<a href="https://www.youtube.com/watch?v=Voe0JZo1JEk" target="_blank">http://www.youtube.com/watch?v=Voe0JZo1JEk</a>
Offline propforward
  • MN, USA
« Reply #36 on: May 26, 2025, 03:17:51 PM »
I made some bushings. Satisfying, but there isn't much to say about it. Nasty burr on the one which I need to polish off. Ho hum.
Offline 55fairlane
« Reply #37 on: May 27, 2025, 10:19:03 AM »
Your engine is coming alone nicely.....are those bushings brass or bronze?  And (because I'm kinda 'tupid) where do they go on this engine
Imagination is much more important than knowledge
Offline propforward
  • MN, USA
« Reply #38 on: May 27, 2025, 11:59:31 AM »
Well, slowly slowly. These are the main bearing bushings for the beam pivot - and…….they are junk.
Following our convo yesterday I checked the bores and they are undersize. Did not expect that. I don’t know why reaming using flood coolant would cause that, but I’m going to make these again and re without flood coolant just to see if the bores come out on size.
I could try and re ream these, but I want to test the process. These are ugly anyway. Do over. Same bar, same reamer. See if the use of coolant vs oil makes a difference. You live and learn.
Another lesson - check the bore size before parting off.
I guess there was stuff to say after all.
« Reply #39 on: May 27, 2025, 12:09:44 PM »
But Stuart,
why make new bushings?
They look good. And a little smaller in the bore isn't so bad. You haven't made the shaft for the beam yet, have you?
Offline propforward
  • MN, USA
« Reply #40 on: May 27, 2025, 12:34:15 PM »
Yes I can save these for sure - or make the shaft smaller - but I also want to understand why my reamer made an undersize hole. I’ve used that reamer before and made on size holes. So I want to investigate. That’s all really.
« Reply #41 on: May 27, 2025, 12:40:34 PM »
Yes, okay, Stuart.
Then the two bushings are for the first wear stage of the beam engine 😉.
Regards, Michael  :cheers:
Offline propforward
  • MN, USA
« Reply #42 on: May 31, 2025, 01:02:27 AM »
The biggest screw up here is that these should be split bushings.
