Ah.... Now I see! That shuttle rod (the orange thing) gives it some hysteresis. It's either one way or the other. You don't have any of those problems with transitioning valves or anything. Clever!Kim
"Piloted part of the shuttle valve term, what does that mean?"A pilot valve is usually a direct acting (manual or solenoid control), small, low-force valve that controls a small pilot flow to push a larger piston/shuttle and thus control a larger flow that needs more force to actuate. Using the hydraulic "leverage" to your advantage. Or, as in your case and more importantly, to create the hysteresis you want. I've only learned recently about hydraulic shuttle valves and valve stacks...and the range of what can be done with them is staggering. We are using some ancient Vickers parts for an actuator we build at work.
Thank you for clarifying how your new design functions - really helps the olde grey matter Per
